Old 02-06-2016, 11:13 PM
TristanBaylis TristanBaylis is offline
Default Protools 12.4 USB audio interface issue causing CPU and Video errors
Got a real head scratcher. So I have been working with Protools 12.4 for the last week. After the a day a had my first AAE 6101, CPU overload error surprise surprise. So I look a HW buffer set it to 1024. Issues still happens. Open a new session with a single track , no audio, still get the error. Switch I/O from my Apogee Duet 2 to the 'built in output', problem goes away. Switch back to Duet problem, switch to built in audio problem goes away. I will also get video errors ( Video engine failed) switch to built in audio that problem goes away.
So I have a look at my Apogee, change the USB cord, re install firmware. No fix. Manually delete all Apogee files and re install, same problem. Should also note, when the error come up., things like spotify also do not work through Apogee. Re install protools serval times, no fix. Apogee seems to work fine with my old macbook pro 2012 running Prtools 10 and 11. I should mention my iMac is brand new running El Capitan. Once error message comes up the only way I can get the Apogee to work again is to pull the USB out the back and then put it back in and re-open my session.
Is anyone else have these USB interface issues with Protools causing 6101 errors and/or video play back errors. Does anyone know what the issue might be. Could I have too much running through USB buses? (3 Drives, Interface, Ilok)...It's never been and issue on my macbook pro.
iMac 5k late 2015 i7 4.0Ghz
24GB ram
500GB flash storage
3x eternal drive 7,200 RPM
El Capitan
Apogee Duet 2
Protools 12.4
Old 02-06-2016, 11:47 PM
Michael Hurwitz Michael Hurwitz is offline
Default Re: Protools 12.4 USB audio interface issue causing CPU and Video errors
Try using a USB 2 cable, not USB 3 and see if that resolves it.
___________________________________
Pro Tools 12HD Native,
Mac Pro 2013-3.5 ghz, 6 Core and Macbook Pro-15"-i7, 2.2 GHz
UAD Apollo 16, UAD Apollo Twin Quad, Aphex 1788 Mic Pre, Presonus Digimax-FS, Hear Technologies Hearback and TalkBack, Dynaudio BM5A.
Old 02-07-2016, 06:30 AM
The Apogee only excepts the old step USB 2 B connectors in the rear, unfortunately I don't think it can be that.
Copy/Paste Issue Causing Audio to change pitch Drumbum7 macOS 2 06-03-2014 07:07 PM
Video Card Irq conflict causing hw buffer errors. broken81 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 06-23-2010 11:03 AM
Video Card causing 9092 and 9093 errors - New discovery and suggested solution mixupandblend 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-11-2009 07:17 AM
Mismatched sample rate causing pitch/sync issue in video Searcher Pro Tools TDM Systems (Mac) 2 02-06-2009 12:19 AM
Digibase errors causing crash when browsing for audio meatmarketstudios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-11-2008 07:45 PM
