I feel like I'm back in 2003. DAE errors 7054 and 1 (!).
Plugins not loading and these errors are thrown up. Also occasionally getting Runtim Error R6016 and PT freezing. New install of Windows just a fortnight ago, reinstall of Pro Tools 10.3.7, all databases trashed etc with Trasher 10.5. Ripping hair out. ![]() If anyone has any ideas or solutions PLEASE let me know. Thanks in advance... SiSoftware Sandra ID Host Name : Thompson-PC Workgroup : WORKGROUP Computer Model : OEM System Product Name Serial Number : System Ser********** Chassis : Desktop Mainboard : ASUS P5WD2-Premium Serial Number : MB-123******* BIOS : AMI (OEM) 0709 03/31/2006 Total Memory : 8GB DIMM DDR2 Processors Processor : Intel(R) Pentium(R) D CPU 3.00GHz (2C 3GHz, 2x 2MB L2) Socket/Slot : FC µPGA478 Chipset Memory Controller : ASUS 82955X Memory Controller Hub 4x 201MHz (804MHz), 2x 4GB DIMM DDR2 670MHz 128-bit Memory Module(s) Memory Module : Corsair CM2X2048-6400C5 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-22-6-3) Memory Module : Corsair CM2X2048-6400C5 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-22-6-3) Memory Module : Corsair CM2X2048-6400C5 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-22-6-3) Memory Module : Corsair CM2X2048-6400C5 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-22-6-3) Video System Monitor/Panel : Samsung SMS24A650 (1920x1080, 30.2") Video Adapter : NVIDIA Quadro FX 1800 (8CU 64SP SM4.0 1.4GHz, 768MB DDR3 1.6GHz 192-bit, PCIe 2.00 x16) Graphics Processor OpenCL GP Processor : NVIDIA Quadro FX 1800 (64SP 8C 1.4GHz, 768MB DDR3 1.6GHz 192-bit) Compute Shader Processor : NVIDIA Quadro FX 1800 (64SP 8C 1.4GHz, 768MB DDR3 1.6GHz 192-bit) CUDA GP Processor : NVIDIA Quadro FX 1800 (64SP 8C 1.4GHz, 768MB DDR3 1.6GHz 192-bit) Storage Devices INTEL SSDSC2CW120A3 (120GB, SATA300, 2.5", SSD) : 112GB (C:) SAMSUNG HD160JJ (160GB, SATA300, 3.5", 7200rpm, 8MB Cache) : 149GB (E:) SAMSUNG SP2004C (200GB, SATA300, 3.5", 7200rpm, 8MB Cache) : 186GB (D:) (F:) WDC WD10EAVS-00D7B1 (1TB, USB2/SATA300, 3.5", 5400rpm, 8MB Cache) : 932GB (I:) HL-DT-ST DVDRAM GSA-H42L (ATA66, DVD+-RW, CD-RW, 2MB Cache) : N/A (G:) ELBY CLONEDRIVE (SCSI, SCSI-2, BD-R, HD-DVD-R, DVD-R, CD-R, 256kB Cache) : N/A (J:) Logical Storage Devices System Reserved : 100MB (NTFS) AUDIO DATA (D:) : 111GB (NTFS) @ SAMSUNG SP2004C (200GB, SATA300, 3.5", 7200rpm, 8MB Cache) 1TB (I:) : 932GB (NTFS) @ WDC WD10EAVS-00D7B1 (1TB, USB2/SATA300, 3.5", 5400rpm, 8MB Cache) SOFTWARE (E:) : 149GB (NTFS) @ SAMSUNG HD160JJ (160GB, SATA300, 3.5", 7200rpm, 8MB Cache) DESIGN DATA (F:) : 75GB (NTFS) @ SAMSUNG SP2004C (200GB, SATA300, 3.5", 7200rpm, 8MB Cache) Hard Disk (C:) : 112GB (NTFS) @ INTEL SSDSC2CW120A3 (120GB, SATA300, 2.5", SSD) Floppy Disk (A:) : N/A Optical Drive (G:) : N/A @ HL-DT-ST DVDRAM GSA-H42L (ATA66, DVD+-RW, CD-RW, 2MB Cache) Optical Drive (J:) : N/A @ ELBY CLONEDRIVE (SCSI, SCSI-2, BD-R, HD-DVD-R, DVD-R, CD-R, 256kB Cache) Peripherals LPC Hub Controller 1 : ASUS 82801GB/GR (ICH7) LPC Interface Controller LPC Legacy Controller 1 : Winbond W83627EHF/EF/EHG/EG Audio Device : ASUS 82801G (ICH7) High Definition Audio Audio Codec : Realtek Semi High Definition Audio Serial Port(s) : 1 Parallel Port(s) : 1 Disk Controller : ASUS 82801G (ICH7) Ultra ATA Storage Controller Disk Controller : ASUS 82801GB/GR/GH (ICH7) Serial ATA Storage Controller Disk Controller : ASUS ITE IT8211 ATA/ATAPI Controller Disk Controller : ASUS SiI 3132 SATALink Controller USB Controller 1 : ASUS 82801G (ICH7) USB Universal Host Controller USB Controller 2 : ASUS 82801G (ICH7) USB Universal Host Controller USB Controller 3 : ASUS 82801G (ICH7) USB Universal Host Controller USB Controller 4 : ASUS 82801G (ICH7) USB Universal Host Controller USB Controller 5 : ASUS 82801G (ICH7) USB 2.0 Enhanced Host Controller USB Controller 6 : VIA VIA VT6214L USB UHCI Controller USB Controller 7 : VIA VIA VT6214L USB UHCI Controller USB Controller 8 : VIA VT6202 USB 2.0 Enhanced Host Controller FireWire/1394 Controller 1 : NEC uPD72873 IEEE1394 OHCI 1.1 2-port PHY-Link Ctrlr FireWire/1394 Controller 2 : ASUS TSB43AB22 1394a-2000 OHCI PHY/Link-Layer Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Send to Microsoft OneNote 15 Driver (1200x1200, Colour) Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : HP Deskjet 3070 B611 series (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Scanners and Cameras Scanner : Hewlett-Packard HP Deskjet 3070 B611 series (NET) (Scanner, USB) Network Services Network Adapter : Intel(R) PRO/1000 PL Network Connection (Ethernet) Network Adapter : Marvell Yukon 88E8001/8003/8010 PCI Gigabit Ethernet Controller (Ethernet) Wireless Adapter : Linksys WUSB600N Wireless-N USB Adapter with Dual-Band ver. 2 #2 (802.11g (ERP), AES-CCMP, 54Mbps) Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64
Drink up, dreamers... you're running dry |
If my memory serves correctly the last time around this was caused more often than not by plugins needing updated. Have you reinstalled any plugs or added new ones lately?
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
All AVID plugs up to date, Waves v9r13, all my IK plugs are latest releases and the only other stuff is Toontrack and Native Instruments but again they're all up to date.
Your hard drives are not doing you any favors
8mb cache? I bet you had those same drives a decade ago when you were getting the errors the first time And I am guessing that you have that Samsung drive partitioned - but that will not help nor make it better Best known method 1 OS 2 target recording drive 3 samples PS and the 5400rpm drive - while you may be able to get away with running a 54k for the OS (I've seen it done before b/c it's has little io) It will not make the cut as a sample drive
The "slow" 1TB is purely a backup drive and the names of the drives is somewhat misleading. Any session(s) I'm working on sit on the SSD and move back to the Audio Data drive when not.
This has only started happening in the last 3 weeks, hence the Windows reinstall. Doesn't appear to have helped.
Session drives should sit in the secondary recording trarget drive
So when you are working in a session and record some audio where is the file recorded to? It should be the secondary drive not ur OS install (ie your C:\ ) This can cause major throughput issues if you're recording back on to your main install OS drive PS you may not be doing that - I'm just trying to check for understanding to make sure what's going on here
Daniel HDX - PT12.5.1 - HD I/O 16x8x8 Win10-Pro (v1709)- 6 Core i7-6850k - ASUS X99 Deluxe ii D-Command Main Unit - 'Ole Blue http://www.sknoteaudio.com/ plugins rock and are affordable. Last edited by YYR123; 09-25-2013 at 12:06 PM. |
![]() ![]() ![]() I'm also concerned about a drive on its last legs, so back up everything now..as in TODAY ![]()
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C https://www.facebook.com/search/top/...0sound%20works I started in this business with nothing..........and I have most of it left ![]() BTW, my name is Dave, but most people call me.........................Dave |
My thoughts too. He's trying to race a Ferrari on a go-cart track.
Too much blood in my drugstream Gigabyte X99 SOC Force Mobo Bios vF6d Intel Core i7 5930k socket 2011 v3 @ 3.50GHz 32GB DDR4 Crucial RAM System: Samsung M.2NVME SSD 960 Evo Record: Samsung M.2NVME SSD 960 Evo Samples: Samsung SATAlll SSD 840 Pro Storage: 2x Samsung SATAlll SSD 840 Pro EVGA GeForce GTX 750 Graphics PT 11HD (v11.2.1) Omni s/pdif w Eleven Rack HD 96I/O Win 8.1 Pro |
You're probably right.
![]() In that case, hit me with some motherboard bundle links please chaps. The Pro Tools PC looks nice but I've already got an expensive and certified graphics card. P.S. SyncBack runs every evening so no data's ever in danger.
Gigabyte X79 / mobo chipset / intel LGA 2011 CPU's
Yet another DAE error - 7054... | Simon Andersson | macOS | 2 | 12-29-2013 05:25 PM |
AAE error -7054 | indoe | Pro Tools 11 | 7 | 07-05-2013 08:44 AM |
dae error 7054 | C V MUZIK | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-26-2013 01:52 PM |
Dae error 7054 | Safjuan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-22-2008 09:36 AM |
ERROR # 7054 | jeffinmarin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 06-10-2002 08:22 AM |
