Do we have a Repeat function bug? (7.1)
Incredibly, if you use the repeat function on an audio session grided to measures and the number of repeats is anything above 20, say 100 or so, if you examine the last portions of audio, THE AUDIO WILL BE HORRENDOUSLY OUT OF THE GRID.
AM I CRAZY AND THIS IS ONLY HAPPENING TO ME? check this example 1-Selection of a Quarter note grid section 2-image to confirm audio bit starts exactly on grid 3-image of 400th repetition (only 52 meas) http://img301.imageshack.us/img301/4765/picture1zx8.png http://img301.imageshack.us/img301/9281/picture2in3.png http://img301.imageshack.us/img301/1980/picture3fh6.png |
Re: Do we have a Repeat function bug? (7.1)
can someone confirm this?
The weird thing is that if I start a session it works correctly, I'm having problems with this particular set of sessions, that come from different sources and mostly from PT 6.XX. Thxs |
This is a known issue. It's because of rounding errors, dependent on the tempo/sample rate relationship. Just select the regions an "Quantize Region to Nearest Grid" (Command+0). That should fix it.
R. |
This didn't happen on my PT 5.1 TDM MIX rig on OS 9. So it can't be THAT DIFFICULT TO SOLVE since it once worked. Even more, I would EXPECT it to be done correctly from the start, I don't see Digital Performer (which I have and can corroborate) having this problem or Logic (which I have and can corroborate)....so the rounding error is a LAME excuse, this is not a $100 piece of equipment, at least my rig is worth nearly FORTY THOUSAND $$, exp chasis, 5 Accel cards, 2 interfaces, ProControl 24 faders. I don't feel understanding about this, this is supposed to be a PROFESSIONAL TOOL, It's very embarrasing to explain some rounding error to a client when he can do this simple function on garage band without a hick-up... C'mon DIGI come up with a Fix LIKE YESTERDAY.... |
R. |
I would like for some Digi guy to post here something about this
It is so totally unacceptable, like the little festering problem that the system freezes erratically for no apparent cause for 3-5 sec and audio still plays and then it resumes with out a problem. WHAT THE HELL IS THAT? I live in constant paranoia when I bounce, looking for the ghost automation error caused by one of these minifreezes. Again this is a very expensive tool, supposedly a professional tool, and again I'm having this sensation that we are Guinea pigs for their half baked products. |
I have had this happen to me a bunch in editing, I do a quick fix and I forget about it - BUT I remember the Digi guy talking about the conditions for the error, and how to avoid them, when I went to the local PT7 introduction a while ago.
Has something to do with tick-based vs. sample-based audio and which editing mode you're in...I think. Not much of a help, sorry, but it is known and it is avoidable.
It's not rocket surgery |
R. |
Repeat Not Working | charmingnerd | Artist Series | 8 | 01-05-2017 06:24 AM |
How do I get my track to repeat? | Kaikuu | Pro Tools SE and Essential (Win) | 1 | 03-07-2012 01:57 AM |
Audiosuite Plug-in list - repeat repeat.......... | sound01 | Post - Surround - Video | 2 | 11-13-2006 01:05 AM |
apple "d" and repeat function puts clic off grid | eastcote | Pro Tools TDM Systems (Mac) | 2 | 10-20-2004 11:28 AM |
Request for function buttons on DIGI 002 to function | stoogee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-05-2003 06:57 AM |
