Old 09-26-2009, 04:33 PM
tanabe tanabe is offline
Question Move to Next Breakpoint?
Hello,
I've been searching on the DUC, couldn't find the answer.
Is there anyway, shortcut to move to the next automation breakpoint, like Tab to transient?
Please let me know.
Best
Watanabe
Old 09-27-2009, 02:11 AM
Default Re: Move to Next Breakpoint?
Not possible.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron
Old 09-29-2009, 10:39 PM
Thanks... Is there any altanative way you guys do?
Old 09-30-2009, 12:59 AM
tj_davies tj_davies is offline
What exactly do you want to do once having reached the breakpoint?
Tim
Mac Studio Ventura 13.6
PT 2020.12.0
www.pearls-music.com
Old 10-01-2009, 08:00 AM
there are so many things to do... move it up or down, delete it... well a lot.
Old 10-01-2009, 08:29 AM
rdolmat rdolmat is offline
...SHIFT-Select to next breakpoint, etc...
cheers,
rich
Old 10-02-2009, 01:27 AM
- Shift-Click the breakpoint keeps the breakpoint horizontally aligned - that way you can move it up and down.
- Option-Click deletes the breakpoint.
Unfortunately there is no shortcut for jumping to the next breakpoint, but as you need the mouse to edit the breakpoints, I think that shortcut is not that important - although not entirely useless. Following shortcuts might help, though:
- Scroll horizontally: Option+PageUp or PageDown
- If you have (at least) two breakpoints within a selection, press option while adjusting and the automation within the selection is altered in proportion.
- Command+/ creates a breakpoint.
Hope this helps,
Timothy
PT 2020.12.0
Old 11-25-2012, 05:31 AM
joachim's Avatar
joachim joachim is offline
Hope this helps,
Timothy
Thank You Timothy ! That Tip (Alt-Drag Breakpoint-Selection) ends now my 3-Year-Frustration ! (Did not get it from the Reference Guide)
Old 04-24-2014, 03:05 PM
phillyt2k phillyt2k is offline
Hope this helps,
Timothy
Is this still the case? I'm trying with no luck
set a breakpoint to 0 db oNeKOG Windows 3 10-16-2015 08:24 AM
Move the red diamond in the tempo bar in the edit window, only some tracks move kingheartless macOS 2 02-21-2013 03:20 PM
Value for Automation breakpoint? perh macOS 3 09-22-2012 05:35 AM
Breakpoint move line in edit window:How to disable TREBLEBLEED 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-12-2007 12:36 PM
Automation and Breakpoint Changes New Hope Media Pro Tools TDM Systems (Mac) 0 11-16-2005 06:20 PM
