toggle mix and edit window shortcut
Please, anybody, I can't toggle mix and edit window with shortcut "CTRL =" (which is very annoying, you must admit). I upgraded from 6.0 to 6.1.1 but the problem stays. Is it due to the WIN XP PRO?
Thanks in advance. |
Re: toggle mix and edit window shortcut
You are holding Ctrl while hitting + aren't you?
Or you could press ctrl/+
Intel I7 920 Asus P6T Digi 002R. Command/8 PTLE 7.1 MPT www.clearspotrecording.com |
No, nothing helps. All other shortcuts are fine, but this one doesn't work. No combination of any key and CTRL modifier is not functioning. Anybody else, please?
Which language OS and which exact version of Pro Tools are you running? Have you tried 6.4cs9 ?
Rail
American english version of XP PRO and 6.1.1. version of Pro tools
are you using a special mouse/keyboard?
check the configuration if you are. another test is to shut everything down and hook up an generic PS2 mouse/keyboard and see if that changes things. |
No, I'm using generic PS2 mouse/keyboard driver supplied by Microsoft.
I repeat, all other shortcuts in PT (and in all other programs: Premiere, Studio9...) are working. Any idea from Digidesign crew? Thanks in advance |
Command+Shift+0 on MacBook Pro not toggling between Edit & Mix Windows | clausiii | Pro Tools 11 | 80 | 12-19-2017 06:19 PM |
Toggle mix / edit window with MightyMouse ? | T-Low | Pro Tools TDM Systems (Mac) | 5 | 12-28-2009 06:42 AM |
the "Toggle Mix and Edit windows" shortcut won't work. | Cal_MArtinez | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 12-16-2007 10:47 AM |
Mix to Edit window shortcut | Cliffy_Boy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 09-29-2003 08:45 PM |
toggle edit/mix window | rogga_bogga | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 02-01-2003 02:46 PM |
