MIDI latency NORMAL ???
Running PT 8.01 > G5PPC > Avid MIDI module > PC88.
I'm trying to record keys... to a drum track and there's a problem when playing that the timing doesn't line up ?? If I hit a key on the piano there's a delay flam affect on actual hit??? When I play the song back it doesn't line up??? |
Re: MIDI latency NORMAL ???
what's your hardware buffer set to??
"Sometimes having limits keeps you sane"- Albee1952 |
buffer at number 4........
hardware buffer sizes are in samples ie: 32, 64, 128, 512, 1024.... check out pages 365-366 in your reference guide.
I believe it's at 128.......
Try dropping it to a lower setting, I tend to notice latency at 128....
It was at 2048 I turned it down to 256 which fixed the problem ......anything above 512 and you starting hearing the delay....
Thanks for your help...... |
Not Normal Latency.......Help! | dmartin714 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-20-2011 05:50 PM |
Is this normal 11R latency? | miketeachesclass | Pro Tools 9 | 14 | 11-13-2010 08:55 PM |
Is This Normal? Latency Issue | rhooton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-19-2005 05:07 PM |
MIDI Question - Is this normal? | Bezo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-02-2004 07:06 PM |
Newbie Question: Enabling Midi Click through normal Audio output | Nekoneko | MIDI | 2 | 11-02-2001 12:50 AM |
