Major MIDI bug
MIDI automation is leaking into the undo queue and causing havoc. Automating the modulation wheel literally means you can't undo anything, as the MIDI automation will change too dramatically (ie 100's undo commands in a bar) to undo an edit. This happens on PLAYBACK of MIDI automation. Also, editing MIDI note lengths while playing back causes crashes, presumably because of the seamless playback not being able to comprehend changes to the sample. This could be tied to the mod wheel/MIDI automation playback issue.
Has anyone else experienced this? The libraries doing this are Spitfire Alternative Strings. Haven't needed the mod wheel for my usual work, so I haven't seen this before. It could be library specific. Kontakt 5.8.1, macOS 10.14.5, PT Vanilla.
Mac Studio M1 Ultra 64GB macOS 13.2.1 Pro Tools 2023.3 Antelope Audio Discrete 8 SC |
Re: Major MIDI bug
Do you have the parameter enabled in the Plug-In Automation Window?
That will happen if you enable a parameter and control it via MIDI CC Edit: Or maybe you have the "Plug-in Controls Default to Auto-Enabled" option checked? |
Re: Major MIDI bug
Thanks for your reply! Removing the parameter from the automation window solved this (so thank you!), but it is strange that this happens - essentially it is the same as the relationship between trim and the volume, two automation lanes controlling the same parameter. It is not a change to undo, just playing back/reading the automation that is written.
Re: Major MIDI bug
I assume Pro Tools thinks you're changing the parameters by steps, since it's MIDI.
It can be extremely useful when you want to record automation to Pro Tools by messing with the parameters in Kontakt with your mouse instead of assigning a MIDI CC. I use that especially with Native Instrument's Thrill. |
Major MIDI problems | Lana Banana | Pro Tools 2019 | 2 | 05-17-2019 04:53 AM |
Help! Major Midi problem after going 10.3.10 | Alécio Costa | Pro Tools 10 | 6 | 02-04-2016 11:17 AM |
7.3.1cs3 MAJOR MIDI BUG | Skyflash | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-26-2007 10:23 AM |
Major Midi Glitch in 7.3.1 | StrangeBoyPro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-18-2007 08:23 PM |
Need Some Major Midi Help | finalcut | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-28-2004 06:21 PM |
