PT 6.4.1. on 10.3.9.
I search if its works the whole evening , because i´ve got an upgrade
for a software wich needs now 10.3.9 http://apbtools.com/Web-Site/TH-S%20v4-E.html At the moment its a G4 1200 Mhz (Prozessor upgrade from 733 MHZ) with 1 GB Ram and MIX Core with 2 888/24 units. And i found my answers here: maybe its help some others.. http://duc.digidesign.com/showthread.php?t=225875 http://duc.digidesign.com/showthread.php?t=222769 but... http://duc.digidesign.com/showthread.php?t=224521 about 10.4 http://duc.digidesign.com/showthread.php?t=223427 IMPORTANT: Only Quicktime 6.5.2 works with 6.4.1 on OS X 10.3.9 scroll down the page: http://www.digidesign.com/index.cfm?...5&itemid=22904 Re-installers Quicktime 7.03 to 7.01 http://www.macupdate.com/info.php/id/7991 7.01 to 6.5.2 http://www.apple.com/support/downloa...cktime701.html Informations: 6.4.1cs4 (the "newest") http://archive.digidesign.com/compato/osx/mix/ update http://archive.digidesign.com/download/cs/ downloads http://www.digidesign.com/index.cfm?...&categoryid=36 mix support etc http://www.digidesign.com/index.cfm?...&categoryid=35 I´m new in this forum, Sorry if I mad a mistake with posting the links. Now I hope its works, or anybody knows some problems? 6.4.1.cs4 and 10.3.4 with quicktime 6.5.1 with http://www.apbtools.com/PDFs/English...al_Add.eng.pdf over coreAudio works fine all the years |
Re: PT 6.4.1. on 10.3.9.
It works. We did it for nearly two (2) years.
I'm running the same configuration. OS 10.3.9 works fine as long as you don't upgrade quicktime.
thanks for answers, its make me hopefully for it
but what is with this problem, because we have also an prozessor-upgrade... http://duc.digidesign.com/showthread.php?t=224521 thanks here we use this system: http://home.arcor.de/koenig_andreas/ its only in german, home-made.... |
3rd party processor upgrades should generally be avoided, but that doesn't mean yours won't work. It's worth a try. You'll probably be fine.
If you find that it doesn't work I currently have 2 1.25Ghz G4's for sale that definitely do work under this configuration. Sounds like you currently have a quicksilver, With a mirror drive door G4 you'd gain a faster system bus and the ability to use bigger hard drives... |
OK I have a po man's setup of a G4 power mac pc @733Mhz running OS 10.3.5 with 512mb 120G,80G
running PT 6.4 interfaced with the 002 Rack. Is there any hope? |
Is there any hope for what? That it will work? I should think so, but you'll likely not get a huge plug-in count on a machine of that speed.
+1 here
10.3.9 Quicktime 6.5.2 i have G4 DP 1ghz maxed with RAM MIX++ w Atto SCSI...no issues at all...great system!! also have OS 9, as a startup disk |
No worries about posting this, People like me need to read these things anyway. Never know when some knowledge in there might come in handy.
