Plug In Delay Compensation
Hi guys,
what is the easiest and most powersaving way to compensate plug in delays on each track, as well as on the master? Thanks, Tim |
Re: Plug In Delay Compensation
ProTools 6.4 ?
I'm still working under os9
Already read about time adjuster, which works ok, but, is there a setting that can set pro tools to NOT bounce the silence before everything starts? Or maybe automatically cut off the silence after bouncing? Thanks for any reply, even if it's a 'no'! Tim |
maybe you might try this to cut your bounces, as an alternative. sonicWorx Basic for Free http://prosoniq.net/html/freebies.html regs
last: PT11.3.1 |
If you hit If you apple/ click on the #'s below the fader in the mix window, you can see how much delay there is and then nudge the tracks where they need to be.
This still is the most predictable and reliable way to do this, IMO Thanks, John
[email protected] |
If I import a session into 5.X from a newer version of software with delay comp. on does it import the audio delay compensated or not?
it is my understandign that RTAS plugs sample delays are not calculated so you need to account for that if using any. is there an easy way to figure out RTAS delays?
How much plug-in Delay Compensation do you use? | Hear Me Shimmer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-15-2007 01:09 PM |
LE delay compensation plug ins | nossnevs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-14-2007 11:57 AM |
Plug-in delay and compensation | Purple | Pro Tools M-Powered (Mac) | 0 | 10-22-2006 03:43 AM |
Plug-In Delay Compensation | guitar131 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 10-31-2005 03:31 PM |
Plug in Delay compensation - Do we have it or not | Lizardpoint | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 10-17-2005 07:07 AM |
