? about amount of tracks
I was just wondering I know that I can only have 32 tracks in PT:LE but is that just for Audio trakcs?
like can i have 32 audio tracks then have aux tracks on top of that tracks... i dont know if im explaining my self good... oh.. Do Aux tracks count as any of my 32 tracks
www.klarityrecordingstudios.com |
Re: ? about amount of tracks
Aux tracks dont count towards the 32 limit. You can use aux tracks to bring the analog out of any midi devices back into the mix, thus leaving the "disk" tracks for actual audio that needs to be recorded. Auxes are also a great way to group things that need the same effect on them. IE= a aux can be the return from a send from a track or tracks that need reverb. Instead of using a verb on each track, create an aux track, bus everything that is going to get the verb applied to it and insert the verb on the aux. This will save you processor power. It works well for lots of other things also. Hope this helps.
Yup, its 32 mono audio tracks (or 16 stereo), to which you can then add aux tracks and midi tracks.
Want more tracks ? YOU CAN'T HANDLE MORE TRACKS ! (my lame Nicholson bit... ) |
yeah i know about using aux sends for effects stuff i just didnt know that
if by having the aux sends if it would take away from my 32 tracks thanks for clearing this up
I seem to be very limited in the amount of tracks I can playback | matt0722 | Pro Tools 10 | 7 | 07-23-2012 01:26 PM |
Amount of MIDI tracks... | greenwall | Pro Tools TDM Systems (Mac) | 1 | 05-28-2010 02:35 PM |
Maximum amount of tracks on an HD5 system? | MX582 | Pro Tools TDM Systems (Mac) | 10 | 08-06-2009 09:20 PM |
maximuim amount of tracks in le with 1 gig | rohan hylton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-10-2006 01:23 PM |
DIGI 002 MAX amount of Rec tracks at once? | fourthtunz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 24 | 08-07-2002 12:45 AM |
