Old 02-10-2020, 06:38 AM
Buzz Moschetti Buzz Moschetti is offline
Default Eleven Lite dry/wet mix
Just starting to experiment with Eleven Lite on PTF prior to going full PT. I had tried Amplitube on my old PT5.1.1 (yes) years and years ago and recall I could adjust wet/dry signal in the insert. But for the life of me I cannot a way to push the Eleven Lite to full 100% wet in the insert. I still hear the dry signal clinking away in the background. I am sure it is just pilot error on my part. Any tips?
Old 02-10-2020, 11:21 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Eleven Lite dry/wet mix
If you inserted the plug-in into your track insert, it should already be 100% wet. Does your audio interface have a direct monitoring feature? Or possibly you are monitoring another track as well that is letting the dry signal through.
Will
System Details
Old 02-10-2020, 04:02 PM
Ah, OK. If it "locked" 100% wet then I will look for some other cause.
Eleven LE, Eleven Full, Eleven MK II Compared Justin1524 AAX Plug-ins 5 11-19-2015 02:47 PM
Eleven Rack / Avid is not producing anymore Eleven Racks is that true or false? Rongpat Eleven Rack 8 02-11-2014 07:42 AM
Eleven Rack with Ableton Live Lite 7 Made2PraiseHim Eleven Rack 8 08-25-2013 05:15 AM
BDF Lite seems EXTEMELY lite manis Virtual Instruments 11 07-23-2009 05:59 AM
Digi Live Lite 6 and M-Audio Live Lite 6 PRS4LIFE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-19-2007 03:52 AM
