Old 01-31-2007, 06:32 AM
mr.armadillo mr.armadillo is offline
Default Search function in \"import audio\" window useless
Since 7.3.1 OS 10.4.8, I've noticed a OS X like search bar in the "import audio" window. Great idea!
But when displaying the search result, it's not possible to import them ("regions to import" window stays empty).
Double clicking on the audio file you want to import results in import audio window being closed.
Old 01-31-2007, 06:46 AM
tj_davies tj_davies is offline
Default Re: Search function in \"import audio\" window usele
Yep,
I think Frank pointed that out last year - and that's actually when I first noticed that (due to the bug) completely useless feature.
Hope Digi can fix it with the next update.
Timothy
G5 10.13.6
PT Ultimate 2019.12.0
www.pearls-music.com
Old 01-31-2007, 07:38 AM
Haha, is it still broken? I think it never worked. At least since 6.4.1 . I just gave up on that function under 6.9 and haven´t tired it since then. It still would be great if it worked.
I guess it´s somewhere low in the bugs-to-fix-charts...
frank.
PTHDn 2020.9 (OSX10.14.6), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM, Xilica Neutrino, Meyersound Acheron
Old 01-31-2007, 08:18 AM
emilano emilano is offline
Yep, i'll second these thoughts. Wonderful idea, got excited to use it, and disappointed when I realized it had a bug and won't work.
Old 01-31-2007, 08:22 AM
But then again, we have the workbrowser which has a great search and add function.
G5 10.13.6
Old 01-31-2007, 08:32 AM
What´s cool behind the idea of the search in the import-window is that it seems to use the finder (spotlight) wich makes it 100 times faster than the workspace. And most-importantly you can control the playback volume in the import-window.
frank.
Old 01-31-2007, 09:28 AM
Sonny Keyes Sonny Keyes is offline
And what's not so cool is that the first instruction in the Pro Tools installation instructions is that you must turn Spotlight off so that the application will run properly!
P.S. I just tried using the Search in the Import window and it is frustratingly tantalizing that you can actually search and find a list of (e.g.) dog barks, only to discover that they won't import...
Sonny Keyes
Ricochet Audio
Toronto
Sonny Keyes
Toronto
http://www.sonnykeyes.ca
Rig 1: 2.8GHz Macbook Pro PT 12.7.1 Logic 10.3.2 Scarlett 18i20
Rig 2: 2.66 QuadCore Intel Xeon Logic 10.2.0 Scarlett 18i20 PTHD10.3.10
Old 01-31-2007, 09:35 AM
Well, there you go. Maybe they should entirely remove this feature to end this episode. Search won´t work when you turn off spotlight and even if you leave it on it won´t work either. ;-)
frank.
Old 01-31-2007, 09:38 AM
JKD99 JKD99 is offline
Hi Sonny,
I seem to remember a Spotlight-related key command that needed to be disabled before installing PT, but I'm using Spotlight itself as "half-a-search-engine" regularly. No crashes, but would this possibly be why my system (since 7.2) takes 30 sec or so sometimes to recover from an Import Audio operation?
Joe Milner
Puget Sound, Inc.
Los Angeles
IMDB
Puget Sound on Facebook
Old 01-31-2007, 10:37 AM
minister's Avatar
minister minister is offline
i rarelt used it, but, for several reasons, i tried using it the other day... NADA! broken. doesn't find ANYTHING! not even "a".
i thought i was being stupid somewhow. i tried it again. couldn't get it to find anything.
i was gonna post something until i saw this.
it seems embarrassing to have such a simple feature broken like that. Digi, how involved is it for a simple fix for somthing like this? any word on when?
thanks for listening.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
9.0.6 still didn't completely fix the Import Audio search field bug mattyharm Pro Tools 9 3 01-22-2012 11:14 PM
Import Audio function doesn't work in 8.03 resway 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 21 04-02-2010 10:03 PM
Import Audio search window results will not import BA Studios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-25-2008 10:00 AM
Search feature in import audio window Studio Studio Pro Tools TDM Systems (Mac) 9 06-19-2007 04:51 AM
useless audio-scrub function... GVDB Pro Tools TDM Systems (Mac) 5 03-02-2001 12:21 PM
