Waveform Size
Dear friends.
I am having problems with the size of the waveforms when recording. Basically, the input levels are correctly set, the channel meter's are safely indicating between -9db to -6db yet the visual waveform on the recorded clips are massive. To the point that one would assume that they are clipping. On play back the sound is fine. I would like to stress that it is not a zooming issue as suggested on other threads. I have tried this and even as far as I can zoom out the problem remains. Many thanks. |
Re: Waveform Size
Zooming in and out doesn't change the height of the waveform.
On Windows, Alt+Shift+Scroll will lower or raise the height of the waveform. On OS X, I believe it's Option+Shift+Scroll.
Re: Waveform Size
Many thanks
Re: Waveform Size
Glad I could help.
Re: Waveform Size
There's also a little button with a wave on it usually near the top left side of the screen. If you press the bottom, it makes the wave smaller and vice versa.
Dave Cournoyer-guitarist-project studio Mac Mini late 2012, i7, Sierra 16GB PT10.3.10HD PT12.5.2 Apogee Mini-Me firewire. |
Re: Waveform Size
Yeah thanks. I am new to PT so I do expect a few school boy error's
Many thanks. |
Re: Waveform Size
Option-A (or double clicking the Magnifying Glass tool) will reset both vertical and horizontal waveform views.
Re: Waveform Size
I was having the same problem!!! Option A worked perfectly! Thank you!!
Re: Waveform Size
One more useful keyboard shortcut; ctrl+alt+cmd+[ to reset all to (vertical) default size.
T
"Don't look; listen!" At work; 2013 27" iMac/i5/2.9GHz/8GB, OSX 10.8.5, PT 10.3.6 At home; Custom Made Mac (Hackintosh) i7 (3770 "Ivy Bridge")/3.4GHz/32GB@2400MHz, Samsung SSD 840 EVO 250GB System Drive, Samsung SSD 750 EVO 250GB Audio Drive, OSX 10.10.5, PT 12.8.1 |
Waveform size | mickeyrouse | Tips & Tricks | 5 | 02-02-2014 10:16 PM |
Waveform size bug ? | Firechild | Pro Tools TDM Systems (Mac) | 4 | 02-06-2012 10:29 PM |
waveform have different size why | nossnevs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-19-2007 04:07 PM |
Waveform size, not track size | Bleitner | Pro Tools TDM Systems (Mac) | 3 | 11-03-2005 02:39 PM |
Waveform size | remote | Pro Tools TDM Systems (Mac) | 2 | 02-25-2003 10:06 PM |
