polarity reverse question
If I have an input patched to seperate processing channels. I know if I adjust the gain on one it will control the other because they are both controlling one preamp. Does the polarity switch work the same way? If I reverse polarity on one channel will it flip the second?
Re: polarity reverse question
The polarity (phase) reverse happens within the digital portion of the signal chain, so flipping phase on one channel won't affect the other. Same goes for HPF, EQ, Dyn, etc. The only control shared when an input is double-patched is the analog mic pre (gain) setting. Sheldon |
Thanks for the quick reply Sheldon!
Polarity Problem | mentalsanityoff | Post - Surround - Video | 1 | 05-02-2012 12:40 PM |
reverse polarity | eggdog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-13-2007 09:45 PM |
Polarity reverse?!! | jimbojimbo | Pro Tools M-Powered (Mac) | 3 | 11-17-2006 04:32 AM |
Phase reverse question | wooofff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 26 | 10-04-2002 10:21 AM |
Polarity | Camilo Orozco | ProControl, Control|24, Command|8 | 4 | 02-04-2000 07:59 PM |
