#121
Re: Identical Crash threads....
Well, too many crashes during crunch time. But that may not be the worst. The random gumming up of outputs(without greying out) when getting close to 192 voices had sealed the deal. I've now downgraded from 8 to 7.4.1. First time I have downgraded PT in all my years of being on the 'bleeding edge'.
#122
This is the best idea I have heard......and the most logical and sensible one |
#123
Where do you disable DSP caching? I may as well have a try, got nothing to lose at the moment Thanks |
#124
In the "System Usage" Window
Mac Pro 2,4 GHz 12-Core Intel Xeon (Westmere) 32 GB RAM, OSX 10.10.5, HD I/O 16x16 analog, HD I/O 16x16 digital, 192, PT HDX2, PT HD 12.6.0 http://www.pelhamundhaas.de/index2.html http://www.pelhamundhaas.de/vita.html www.3-p.de www.imglashaus.de |
#125
#126
Ive turned off the DSP cache and it has done nothing to stop the crashes and bus 0x0 errors....still getting them as before |
#127
What do you mean by 'there is a definite issue with fade files' - what are you seeing, exactly? And when do you get the bus errors? What about the crashes - when do they occur and what are you doing? Can you post your crash logs? Having your complete system details, including a plug-in version list, would really help. If you can put all of it in one post, so that I don't have to go looking through several posts to gather it all, even better. |
#128
Can I also get more info on your system configuration - as much detail as possible, as well as crash logs and a plug-in version list?
#129
Hey Digi, since you're reading this post, can you give us an update, let us know what direction you're looking at when you say you have clues as to what could be causing the FWCallback crashes?
We're all anxiously awaiting some news, any news! |
#130
As mentioned before the FWCallback is a complete red herring. We have looked through many of these crash logs and there are several causes, many of them unrelated. So, while you're all posting in the same thread, it's very likely that only a few of you are experiencing the same crash cause.
This is why I'm asking for as much info as possible about what each of you are doing at the time of the crash, your complete system details (please, as complete and detailed as possible!) and your crash logs - this way we can correlate with the data we have to see if there's any pointers to possible causes. We have some leads and have them in testing, but there's a lot of data to sift through here and no solid repro cases for any of them. |
(12) 8.0.1 threads. (4) Legacy threads. Jeez!! | Sean Russell | Pro Tools TDM Systems (Mac) | 35 | 09-18-2009 07:59 AM |
Is 7.4.2 HD identical to 7.4.2pr HD? | CHD | Pro Tools TDM Systems (Mac) | 7 | 06-22-2008 01:58 AM |
Identical Unique IDs?? | Rizman | Pro Tools TDM Systems (Mac) | 0 | 05-04-2004 09:23 PM |
Mulitple identical icons | mrmxed | Pro Tools TDM Systems (Mac) | 9 | 09-15-2003 01:03 PM |
Mix cards identical for PC/Mac ? | James Thomson | Pro Tools TDM Systems (Mac) | 1 | 02-17-2003 09:24 AM |
