MP3 Option adds silence to start of file
I'm trying to make a simple loop into a MP3. Everytime it adds a tiny bit of silence to the start of my file which causes the loop to be out of sync. I have tried a number of different combinations in the MP3 export dialogue box, but nothing seems to work. When I save the file as a Sound Designer file there is no silence added. I would really appreciate it if anyone can help me with this problem. Thank you.
Groovy |
Re: MP3 Option adds silence to start of file
Read recently that that is normal. The cure seems to be to use a MP3 editor to remove the silence. There are apparently shareware editors available. Maybe someone here has a suggestion...
MR
Learn to listen. Listen to learn. |
Thanks for the reply Mike. That is really disappointing to hear. First I have to fork over an extra $20 to buy the MP3 Option and now it doesn't even help me acheive what I need. Can anyone suggest a good editor for me to get?
Thanks, Groovy |
I don't know how good the quality of the ProTools mp3 encoder is, but I've found that the best sound MP3s I've heard used the LAME encoder.
You can download a LAME encoder plugin for iTunes on versiontracker.com Then bounce to AIFF, import that into iTunes, and convert to mp3 with LAME. Use -alt preset extreme, and you'll be happy. |
A follow up...
"Audion" has the LAME encoder and waveform MP3 editing. http://www.panic.com/audion/ Quicktime Pro reportedly allows for MP3 editing Why the silence? http://www.geocities.com/altbinaries...l/mp3gaps.html Hope this helps, MR
maybe i should start a new topic -- but do any of you guys know how to convert aif files to aac? itunes 4 does it, but you have to use osx (i'm an os9 user -- and while i COULD launch my ibook in osx, i'm a bit superstitious -- not wanting to screw antying up w/my os9 digi002/ptle setup!).
steve |
mp3 bounce adds to file length? | bogasproductions | Pro Tools TDM Systems (Mac) | 14 | 02-05-2010 08:26 AM |
PT adds panning data when I import an OMF file then move the region to a new track | Panacci | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-28-2009 07:22 PM |
silence inserted at start and end of mp3? | azenis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-21-2008 04:34 PM |
Strip Silence option | Mystic | Pro Tools TDM Systems (Mac) | 8 | 10-06-2006 07:31 PM |
Bounce adds silence? | Jaysus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-18-2005 03:42 PM |
