Old 12-12-2005, 08:00 AM
dklcn dklcn is offline
Default Can I use a PA output as an input for Mbox?
Does anyone know if I can take the output from our PA, which has 10 mic inputs, and run the output into one of the inputs of my Mbox and record with protools? I want to record drums by using 6 or 7 mics, adjust levels through the PA, then record through one of the inputs of the mbox. I'm concerned there would be an issue with the power output of the PA screwing up the mbox, since the mbox is drawing power seperately from the computer...
any suggestions on whether I can use this PA as a microphone mixer?
thanks!!
Old 12-12-2005, 08:31 AM
Camilo Toledo Camilo Toledo is offline
Default Re: Can I use a PA output as an input for Mbox?
Yes, you can. Set the input levels (trim or gain) on the mixer correctly, too much input will result in distortion. Bypass the pre amps on the mbox. Set the master level on the mixer so that you have a good signal going out, and without overloading the mbox.
Since this is going to be a stereo recording, the whole drums set into two channels, pan the drums in the mixer, leaving the bass drum, snare and hihat centered, use compression, EQ, and even reverb to get the best sound possible and the right drum mix. This takes a lot of work, good luck.
Camilo Toledo
Old 12-12-2005, 08:52 AM
Thanks! Another question... How do I bypass the pre amps on the mbox?
Old 12-12-2005, 09:50 AM
plug into the line (TRS) inputs(the center of the combo jacks). You could also plug into the inserts with a special cable but you probably will not hear any improvement.
Old 12-12-2005, 10:27 AM
david_brown14 david_brown14 is offline
Also, if your mixer is powered, make sure you are not using the amplified output to feed the Mbox.
Old 12-12-2005, 03:19 PM
Matt Whritenour Matt Whritenour is offline
you beat me to this one.
also
y would u pan ur hi-hat center?
www.klarityrecordingstudios.com
MBox Pro 3G-no output/input one day after 1.1.2 Seth Thomas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-31-2012 08:50 AM
MBox Pro 3G-no output/input Seth Thomas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-29-2012 05:32 PM
Mbox 3g not listed as input or output. raduran Pro Tools M-Powered (Mac) 1 08-04-2011 06:12 PM
Can i link output to input in mbox pro? nirels 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 10-01-2009 12:10 AM
No midi input and output on Mbox 2 Lowik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 07-02-2009 06:55 AM
