Old 07-08-2007, 11:42 AM
tromostheory tromostheory is offline
Default sustain cuts out while recording midi
I have a digi001 with a fairly powerful pc that is very stable in all other respects. When I record a midi track, usually triggering a sampled piano, the sustain will cut out randomly. I've tried both reason pianos, and Akoustik piano, and I've tried PT 6.1 and 6.4. Any ideas as to why this might happen? thanks.
Old 07-08-2007, 05:29 PM
jsmooth226 jsmooth226 is offline
Default Re: sustain cuts out while recording midi
you might have more than one source selected for midi input...try making sure there aren't multiple input sources
Problems with MIDI Sustain Pedal while recording ChrisSimon Pro Tools TDM Systems (Mac) 72 06-25-2014 10:30 AM
Sustain problems while recording MIDI play4theworld 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-08-2010 07:09 AM
Sustain pedal cuts out while recording. Can't figure it out. jmeharry 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-09-2009 09:13 PM
Problem with recording MIDI piano sustain pedal Chris7514 MIDI 5 06-11-2008 12:56 AM
Sustain Pedal in Midi recording in PT LE Arya44 Tips & Tricks 1 11-09-2003 11:25 PM
