Old 09-04-2015, 08:39 PM
Barry Johns Barry Johns is offline
Default Digidesign Sync
I just picked up a Digidesign Sync I/O for $35.00. I have 2 192 I/O's, a Lynx Auora 16, and a presonus 8 channel mic pre that I only use it for its AD/DA via ADAT to send 4 stereo headphone que's to a headphone amp x 4 to free up the rest of my I/O's for tracking and incorporating outboard.
Everything has been fine to this point without it, but for $35, what the heck. I'd have to buy more BNC Cables to set it up and don't want to waste money if it's not going to yield me better results.
Will I gain anything by using it, or should I just put it up on eBay as they typically fetch $100 or so!
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors.
MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp
Old 09-04-2015, 10:43 PM
Craig F Craig F is offline
Default Re: Digidesign Sync
it adds the VSO option (it is limited range)
locking to Bi or Tri-Level if you're doing Post
LTC for video or a multi-track
will this help you, only you know for sure
Thank you,
Craig
Old 09-05-2015, 06:48 AM
nst7 nst7 is offline
It also helps for using Satellite Link where you link two HD systems together to operate as one. Don't know if you would be doing that.
As for resale value, Someone can use it for Avid's trade up to the newer Sync HD for almost half off.
Old 09-06-2015, 03:03 PM
Exclamation Re: Digidesign Sync
Originally Posted by Craig F View Post
Tri-Level
Only if it is a SYNC HD. The SYNC I/O does not recognize tri-level sync signals.
Old 09-06-2015, 06:52 PM
you are correct
Thank you,
Craig
Old 09-06-2015, 08:36 PM
So basically I have a 30.00 paper weight?
Old 09-07-2015, 07:43 AM
elicious elicious is offline
hey barry, no one has mentioned loop sync yet.
since internal clocking is better than external clock,
and loop sync is better than clocking multiple 192's to word clock.
when you own multiple digital devices that need to sync to the same clock,
it's best to use device's and method's that obtains the best clock for all devices.
sync i/o has tighter sync since Digi designed it specifically for that purpose.
that's what we use ours for, besides VSO, syncing to 2 inch, adats, etc...
hth,
e
ihatetyping
FS: Digidesign SYNC I/O twdwyer Buy & Sell 0 11-22-2013 07:58 PM
FS: Digidesign Sync I/O Meads Buy & Sell 0 04-08-2013 03:40 PM
Digidesign Sync I/O Phil Pelissier Buy & Sell 1 02-15-2013 02:08 PM
Digidesign Sync IO $400 millionbit Buy & Sell 0 02-08-2013 03:51 AM
Digidesign Sync Vs Big Ben on HD gmfilmco Pro Tools TDM Systems (Mac) 3 09-07-2005 10:07 PM
