Old 08-18-2005, 10:03 PM
thornlab thornlab is offline
Default Plug ins do not respond
Hello everybody,
Since last night I've had a weird problem: not one "instrument" plug in is responding to MIDI. Standalone are working fine, except the Pro 53 set up does not even recognize the 001 interface.Haven't changed any configurations.
Runnung 001 on G4 733mhz 1.2G RAM PTLE 6.4
Also, anybody using Fxpansion? If so,any problems there?
thnx
Old 08-18-2005, 10:20 PM
Beric Clapton Beric Clapton is offline
Default Re: Plug ins do not respond
I had the same problem too. I run Albino 2 via FXpansion VST2RTAS. I insert the Albino into an aux track, then assign a midi track to Albino. When I play my controler, it seems that Albino cant receive any midi signal. When I use mouse to click on the Tap button on Albino, it still play the sound. The VST2RTAS works perfectly with other VST plugins. Anyone have any idea to fix this? Would be very appreciated. Thanks in advanced.
Old 08-18-2005, 10:46 PM
Ha,i'm not alone on this one...however i'm not even using Fxpansion. Just straight midi track to aux...
When loading previous session, plug-ins won't respond! fightingcory 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-02-2009 11:16 PM
digi wont respond to 003 factory plug-in issues.worst tech support ever brooks1462 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 01-24-2009 09:37 PM
Plug-Ins/Effects respond very slow! RC99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-08-2006 12:41 AM
PLEASE RESPOND....AGAIN!!! celestialsound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-24-2006 02:00 AM
