Old 06-30-2004, 07:49 AM
Iguana Iguana is offline
Default Pro Tools loses connection with motor mix error
Hello All,
When I updated to 6.1 my motor mix would lose connection with the Digi001. If I click play, it regains connection but will lose it again when I stop. I have tried several different Midi setups. I have a USB midisport and have had the same problem while using it with the motor mix. Digidesign was unable to help me So, I updated to 6.4 and have the same problem. Actually, it is worse because they don't support the motor mix and consider it "legacy." That's a pisser:)
Any help would be appreciated because I have a mixing session this Friday and it would be very nice to have the motor mix working.
Thanks,
Patrick
Old 06-30-2004, 08:03 AM
Bazzle Bazzle is offline
Default Re: Pro Tools loses connection with motor mix error
First place I would look is at your cables.Do you just get the lost connection box or do you get the 82 byte token error?
Bazzle
Old 06-30-2004, 08:56 AM
I have tried new cables. It is a software issue as far as I can see. As I said, it always regains the connection after I use the mouse to click play. The error is the standard " Pro Tools has lost connection with the Motor Mix. Please recycle and so on. Thanks for the cable suggestion. Have any other suggestions?
Old 06-30-2004, 09:00 AM
Did you download the Legacy Controllers .dll files and install them?When I have problems like that I always go for the Repair installation option in ADD/REMOVE programs.Works wonders sometimes.If your going to do that delete your DAE Prefs file first.Then it will default and maybe clear it up.Other than that I have nothing else.Good Luck.
One more thing if you installed the Legacy .dll make sure the previous version is not still in the folder.
Bazzle
Old 06-30-2004, 09:17 AM
Thanks. I did download the legacy .dll
I will try your solution and let you know.
Thanks,
Patrick
Old 06-30-2004, 12:42 PM
Has anyone had success using the motor mix with 6.4 and the digi001?
Thanks,
Patrick
Old 06-30-2004, 02:47 PM
Yes there was a thread last week and someone was having success.Do a search for Motor Mix it will come up.I use a HUI but we have had the same issues.
Bazzle
002R loses connection 6figgas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-07-2008 01:31 PM
002R Loses connection w/PT LE 7.3.1 badseed79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-09-2007 10:17 PM
Loses connection with 002r when importing audio joejackson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-24-2006 12:08 PM
Pro Tools Loses connection with 002? please help. joeH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-16-2005 12:26 PM
001 loses connection mersisblue 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-28-2004 08:47 PM
