Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 08-11-2018, 08:03 PM
xrekcor's Avatar
xrekcor xrekcor is offline
Default what do you use? (interface advice)
I am looking to upgrade my audio interface. I currently use a UR44 which I have found to be a pretty solid performer.... but then again I haven't had a lot of experience with many others, if at all. I'm looking to extend the capabilities in relation to an interface I/O to 16-24 inputs. and so would like to hear from people who are using similar and what they are using. interface/desk......
the options that currently interest me are....
Presonus StudioLive 24.4.2 or similar (which can also be used as a FOH desk)
Focusrite Scarlett 18i20 + Scarlett OctoPre (officially supported) but my UR44 isn't and PT does a better job at finding it than Cubase.
Presonus Studio 1824 + DigiMax DP88
if it is going to be an interface it needs to be able to be rack mounted. apart from that I am interested in hearing what peoples experience has been. what limitation does usb/firewire/thunderbolt have or not have and does this effect the amount of active inputs you can run which I guess works in conjunction with processing power. I would be using my MBP listed below.
Cheers
Rob
MBP 15” 2018 macOS Big Sur 11.6.8 Touch Bar and ID
2.2GHz 6 core 8 gen Intel Core i7 processor (TB’s to 4.1GHz)
32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard
Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II
........and a bowl of M&M's
Old 08-13-2018, 04:43 PM
xrekcor's Avatar
Default Re: what do you use? (interface advice)
looks like I have a Presonus StudioLive 24.4.2 offer for AUS$1000.00 which will be cheaper than the 2 interface options in my first post. so any experience folks have had with this desk and PT would be greatly appreciated.
Rob
Interface advice tonyreed Pro Tools 12 9 05-06-2016 03:30 AM
Interface advice Roger Stauss Pro Tools 9 3 09-30-2012 02:25 PM
M-Powered Interface Advice! jackgnic Pro Tools M-Powered (Mac) 12 06-17-2008 12:18 PM
Need advice: 88x/16 interface kenlac Pro Tools TDM Systems (Mac) 2 06-21-2000 04:12 PM
Advice on modifying 888/24 interface Ian Greaves General Discussion 1 01-21-2000 07:58 AM
