Old 08-12-2020, 06:28 PM
reflekshun reflekshun is offline
Default Is this normal performance for Artist Mix?
I have made a video of the performance I'm getting using the Avid Mix.
I have just updated to the latest eucontrol and firmware.
As you can see in PT and LPX, moving a physical fader is VERY jittery (this translates to very jittery automation too when recorded). I have to use mouse to fix every single automation recording I do, which seems counter productive to the whole point of this thing.
As you can also see at the end - moving faders on PT and LPX will move faders on the hardware perfectly, very smooth and zero jitter.
https://www.youtube.com/watch?v=K5p5...ature=youtu.be
Is this normal?
If not any ideas on what might be the cause of this jitter?
Old 08-13-2020, 06:47 AM
EddieJones's Avatar
Default Re: Is this normal performance for Artist Mix?
Obviously, this is not normal and usually caused by the network. How are you connecting the Mix to PT... direct cable or through a router or switch ?
Old 08-13-2020, 03:00 PM
corym corym is offline
Did you figure out the problem you were having?
-Cory
Old 08-14-2020, 07:16 AM
EddieJones's Avatar
See this thread http://duc.avid.com/showthread.php?t...2&goto=newpost
Old 09-16-2020, 02:55 PM
Thanks for the reply! I am connecting with a direct cable from the avid mix to the cat5 network plug on the back of an iMac Pro.
I also tried swapping out the cable for another newer one today, but same performance issues remain there too.
Considering it's so direct I am a bit out of ideas on what could be causing connection issues, I'm not very well educated on the software side of networking either. Any ideas to try would be greatly appreciated.
I'll be checking this thread more often, sorry I took a while to get back on this one!
Old 09-16-2020, 03:18 PM
EddieJones's Avatar
Check this out and make sure the touch and faders are OK https://www.sweetwater.com/sweetcare...lt-there-test/
Old 09-16-2020, 03:31 PM
Just went through all of those tests and they work 100%
Old 09-16-2020, 03:34 PM
EddieJones's Avatar
and the CPU is not overloaded on the Mac? Sorry thinking of everything.....
Old 09-16-2020, 03:44 PM
No worries at all, appreciate the efforts - it's happening on a blank project with one empty audio track on an iMac Pro so the CPU is not struggling here.
Old 09-16-2020, 08:24 PM
EddieJones's Avatar
Do you have any other controller enabled in Logic ?
Can I change Eucon Layouts with an Artist Mix or Artist Transport? amathie Artist Series 10 09-21-2017 07:29 PM
Artist Chat window in Avid Artist Community taylor4814 Pro Tools 2018 0 01-25-2017 06:30 AM
2 avid artist mixes and one artist control V2 for sale Brandonx1 Buy & Sell 2 03-21-2016 09:55 PM
Touching Artist Transport Freezes Up Artist Control in Logic sonofmack Artist Series 1 03-13-2013 08:22 PM
>>poor MBox performance! is this normal? megahurt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 12-17-2003 11:48 AM
