Old 09-23-2012, 08:50 PM
Fabulous Fabulous is offline
Default Virtual instrument installer fail
When attempting to download the avid virtual instruments 10.3 with the installer I am getting this message -
"Could not find the requested file on the server. Contact the author of the page that contains the link. This download will be cancelled."
Does anyone know what to do about this? I have no idea how to contact the author or if its even possible? Is there a link that works?
Cheers
Old 09-23-2012, 09:13 PM
AvidCS's Avatar
AvidCS AvidCS is offline
Question Re: Virtual instrument installer fail
Where are you trying to download the file from? We can check it out if you can provide more info, thanks!
Old 09-23-2012, 09:35 PM
Default Re: Virtual instrument installer fail
From here -
http://secure.digidesign.com/service...rticleId=43572
Old 09-23-2012, 09:49 PM
AvidCS's Avatar
Tried both "Download" (which uses the Download Manager) and "click here" (simple file download) and both work properly.
Does it fail for you with either link? At what point do you get the error?
Old 04-04-2013, 02:17 PM
sunking3 sunking3 is offline
I installed Pro Tools 10HD 10.3.2 and then installed Avid Virtual Instruments 10.3 "Installer." I see Vacuum and DB33 plugins in my plugins selection drop down and I am able to select and open them however, I do not see anything that leads me to their presets. If I click on "Import Settings" under 'Presets" I only find myself at an empty Vacuum folder. I have looked in the Applications-AVID-Avid Virtual Instruments and there I find, Boom, Xpand2, Mini Grand, Structure Free and Structure Quick Start but find nothing for Vacuum.I have tried to spotlight search for Vacuum or Vacuum presets and I can find nothing. Ultimately I cannot load presets in any of the Avid Virtual Instruments. I have used a preset in Vacuum that I cannot find and I need it desperately.
Any suggestions?
Where did the Virtual Instruments Mac installer boxman macOS 3 05-13-2013 10:06 PM
Solved: PT10 Virtual Instrument Installer won't download tooold macOS 0 01-24-2013 02:02 AM
PT HD 10 Virtual Instrument Installer petesteen Pro Tools 10 1 03-22-2012 04:51 PM
Avid Virtual Instrument Installer, HELP!!!! MusoPro Virtual Instruments 6 01-16-2012 10:21 AM
Instrument Tracks fail to re-activate Buff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-23-2007 08:46 AM
