DigiCS: PT6 Plugin on fly bug report
PT6 MIx plus on OSX 10.2.3
G4-400 256 meg ram When instantiating a mono plug on the fly, stereo track will go wildly out of phase. Playback must be stopped for this to be corrected. For instance: I can solo stereo track of overheads and put a plugin on the snare track(not soloed) on the fly....the overheads phase will shift radically. I hit the space bar twice to stop and restart...everything is fine again.
Kevin Perry Chameleon Music |
Re: DigiCS: PT6 Plugin on fly bug report
Confirmed.
Hallo,
PT 6.0.1, OSX 10.2.5 I can't confirm this. |
bump
Kevin,
Have you tried this in 6.01? Does the problem persist? Mike |
Problem does still persist in 6.01 PT6 OSX 10.2.5
At AES the Digi demo dude even said that feature will not work properly when using any PI to change from a mono track toa stereo track.
Right...but I'm not changin a mono track to a stereo with the plug. PT tells you it has to stop when you do that. If you insert a mono plug on a mono track on the fly- then any stereo track playing becomes radically out of phase with itself. Makes on the fly useless when all of a sudden stereo tracks get all screwy. You have to stop and restart.
I believe the problem occurs only with Mix systems. Unfortunately, I don't believe it can be fixed - it's a limitation of the hardware, which was designed long before on-the-fly plug ins came along.
dc |
bump
raw
Ron Wasserman http://www.ronw.com http://www.imdb.me/ronwasserman http://www.fishertheband.com Mac Pro (Late 2013) 3.5 GHz 6-core Intel Xeon E5 - 32 GB Ram / 1TB Flash Storage - Avid HD I/O - Latest Mac OS - HDX3 - Latest PT Version. |
Question for DigiCS. | LoZion | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-04-2006 11:36 PM |
DigiCS | AudioOIART | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-16-2006 05:06 PM |
Waves L2 plugin wrong latency report in bypass | tapani | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-22-2004 01:44 PM |
DigiCS: Bug in 6.4 HD | ckevperry | Pro Tools TDM Systems (Mac) | 0 | 10-08-2004 12:28 PM |
Question for DigiCS | ckevperry | Pro Tools TDM Systems (Win) | 3 | 10-26-2000 08:42 AM |
