Re: PT wouldn't play even one track
Do you get playback issues when you choose a different playback engine in Pro Tools. Take the 18i20 out of the equation and just use the Mac output to test. |
Have you tried checking the Activity Monitor app when this happens? Anything suspicious happening in CPU or memory?
I would also check if there is anything happening in the Task Manager window in PT. Try also holding down shift when opening a session that shows this behaviour. All plugins on the session will be disabled.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
Hm, it looks like trashing prefs again after the reinstall helped. All good for now. thanx
Mac Mini M1, 16 GB Ram, OSX 10.181.1,Focusrite Scarlett 18i20,Behringer ADA 8200,Pro Tools 2022 2xGlyph hard drive 750GB |
How can this track play? | kywildcat79 | Pro Tools 10 | 1 | 03-11-2014 07:58 PM |
When I enable a track to record and then hit 'play' the track will remain silent | Rainerbird | Pro Tools M-Powered (Win) | 2 | 08-07-2009 09:41 PM |
Pro Tools wouldn't play until... | mattrussell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-23-2007 09:55 AM |
Can you play along with a track without recording? | newathis | Tips & Tricks | 5 | 01-16-2004 07:56 PM |
Mute on audio track switches off when I play the track | el biciclista | Pro Tools TDM Systems (Mac) | 3 | 07-29-2003 10:54 AM |
