System Preferences Shows MBox2 and MBox2 Pro
Hi. I have a MBox2, but when I go to System Preferences, under "Other" it shows icons for the MBox2, which I have, and the MBox2 Pro, which I don't have.. Everything is working fine, but I don't understand why the MBox2 Pro icon is showing. Is this a glitch? Anyone else have this problem? Like I said before, everything is working fine, there's just that MBox2 Pro icon under System Preferences. Anyways to remove this icon, or should I just keep things the way they are since the extra icon isn't causing any problems?
Thanks, -Adam [email protected] |
Re: System Preferences Shows MBox2 and MBox2 Pro
That is normal. No worries. I have an MBox 2 Pro and both of those preference panes show up on mine as well. There's actually a simple way to keep unused preference panes from appearing, but I wouldn't recommend it. Just leave as is and all will be fine.
It won't hurt anything to leave it, but you can remove Mbox 2 Pro preference pane without causing any problem. You can use the instructions listed on the Coreaudio page....
Administrator Avid Pro Audio Community |
thanks. i appriciate it.
-adam |
Mbox2 Pro & Mbox2 Micro on the same system | Freakazoid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-16-2011 01:38 AM |
Upgraded from Mbox2 to 002 but there's no 002 software in System Preferences | bazeboiee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-05-2010 09:43 AM |
mac system preferences shows mbox2 fiirmware instead of 002R | muscmp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-04-2007 07:15 PM |
mac system preferences shows mbox2 fiirmware instead of 002R | muscmp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-04-2007 06:49 PM |
Help! MBox2 firmware update killed my mBox2 | kova | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 09-27-2006 05:19 PM |
