Old 07-27-2010, 08:03 AM
Audio85 Audio85 is offline
Default Pro Tools PROBLEMS!!!! Notice Plural
I can not do anything with any plug-ins or adjust things without this popping up. What does this error message mean? And what can I do to fix it?
Could not complete your request because file not open (-38) while reading Protools-vdb.
I'm kinda getting scared that I don't have enough space/room on my computer to hold everything. I don't have a lot of PT files on my computer, but I'm just getting a strange feeling that I might screw myself over eventually when I'm recording numerous bands at one time or mixing a project while recording another.
If possible what are the correct steps to take in my computers capabilities to make sure I have everything I need to have enough storage, CPU usage, buffer size is good, just everything, you would need to correct or know in a typical recording studio session with the limited things that I have. I realize that with the limited things I have, I am "limited", but enough to not lose anything or disable my progress, etc. Basically, what is the correct PT set-up for an:
iMac version 10.5.8
Processor: 2 GHz Intel Core 2 Duo (1 processor)
Memory: 4 GB 667 Mhz DDR2 SDRAM (which i think is the highest i can go)
# of Cores: 2
L2 Cache: 4MB
Bus Speed: 800 MHz
Mbox 2
Pro Tools LE 8
I also realize that an external drive is going to help and believe me, I'm going to get one with at least a terabyte, but I need to get money first. PLEASE HELP, I HAVEN'T LOST ANYTHING YET!!! I JUST DON'T WANT TO.
Also, when I'm consolidating my tracks and I have some that have elastic audio on them and then delete the "unused regions" is that going to affect anything in the final mixing or some hidden audio within the PT session? Just wondering. Is there also a reason why PT is opening very slowly, to the point where I have to force quit because it's not responding when trying to load the mix window?
Thank you, I'm sorry for rambling
Old 07-27-2010, 08:10 AM
Dism Dism is offline
Default Re: Pro Tools PROBLEMS!!!! Notice Plural
iMac version 10.5.8
# of Cores: 2
L2 Cache: 4MB
Bus Speed: 800 MHz
Mbox 2
Pro Tools LE 8
You NEED an external drive to put your sessions on. It doesn't need to be a terabyte... you could buy a 250GB or a 500GB for around $50-60. As long as it is FireWire and has an Oxford chipset, it's fine. No need to overpay, but it is a system requirement for Pro Tools to run properly.
That being said... if you are running low on disk space... that is just asking for even more problems. Everything else about your system should be fine. Make sure you always have at least 20-30% hard disk space left, and don't try to squeeze every last GB out of it, because that lowers the life of your drive, and causes a lot of other issues.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 07-27-2010, 05:48 PM
Park Seward's Avatar
Park Seward Park Seward is offline
Yes. Gotta, Gotta get it!
If you have upgraded from an earlier version, check your plug-in compatibility.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 07-27-2010, 06:10 PM
www.otherworldcomputing.com has the Mercury line of firewire drives and those are a great deal(and work with PT). You should always have at least 15% of free space on all hard drives. If you don't have that much, you should move.archive whatever you can to free up space. Commiting Elastic Audio tracks(to turn EA off) will help with system resources.
Anyone notice? Demigrind 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-05-2006 10:42 AM
Anyone Notice.... JCBigler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-02-2004 10:54 AM
Anybody ever notice? Michael Cottrell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-30-2004 12:29 PM
Pro Tools Crashes without notice.. trelobas Pro Tools TDM Systems (Mac) 4 12-20-2003 05:06 AM
PT6.1 weird problems-Did you notice them? ricren Pro Tools TDM Systems (Mac) 6 08-08-2003 04:37 PM
