Old 02-16-2021, 01:57 PM
melodydetective melodydetective is offline
Default HDX/HDIO intermittent connection issues
Hi folks.
I have a ticket out on this but wanted to see if anyone has had this.
2013 Mac Pro. 10.14.6. Latest PT and HD Driver. HDX card in a Sonnet PCIe thunderbolt 2 chassis.
I’m having odd issues with the HDX driver. In ProTools it’s represented in two ways: one, occasional pitch flux. Two, sometimes PT won’t go into play or locates to the end of the session and then won’t go into play. So that sounds like clocking issues. Changed DigiLink cable - same story. No other clock connected.
When I try to use the HD driver in coreaudio with Cubase, periodically I get the “hardware has been removed from your computer” pop up - then it disappears and the HDX is back, for a while.
Swapped thunderbolt cables with no change. Nothing else is in that thunderbolt bus but two PCIe SSD’s that are when added to the HDX well within bandwidth limitations.
Any of this sound familiar to folks?
M2 Mac Studio Ultra 192/4; Lynx Aurora 16; PT Studio, Cubase, Logic, DP; Video Sync; Aja T-Tap; Metagrid Pro; TouchOSC; VEPro; Acoustic Samples, SM, AM, SF, EW OPUS, JFK, JFC, MTBF, TL;DR
Last edited by melodydetective; 02-16-2021 at 11:56 PM. Reason: Added detail and fixed cables typo
Old 02-16-2021, 03:29 PM
Default Re: HDX/HDIO intermittent connection issues
No recall of these issues, but some suggestions.
First
occasional pitch flux == pitch flutter? Pitch change? Describe clearly what exactly happens.
Swapped thunderbolt bales with no change. == swapping thunderbolt cables causes no change?
Is the chassis on it's own Thunderbolt bus. No display or disk on the same bus?... remember that the six Thunderbolt ports are connected to three separate Thunderbolt busses. Google for more info. Put the chassis on a dedicated bus... should not be needed but I'd try it anyhow.
Can you test the HD IO or HDX card in another system.
What exactly is connected to the HDX Card? One HD IO? Remove anything else.
Does your setup past Digitest? Can you get it to pass normally, and the when things go bad rerun Digitest and see if/what error it fails with.
The Mac is definitely optimized to not sleep?
Old 02-16-2021, 11:50 PM
All good suggestions.
Pitch flux means it slews like a tape machine if someone put a finger on it. Slows then resumes.
Bales? Typo. Cables is right.
Chassis is on its own buss. The three are arranged oddly on the 2013 MP -
1 2
1 2
3 3
I could conceivably test it in my cheesegrater. Hoping not to but those may be the breaks.
Only the HDIO is connected.
All devices pass digitest. But that is an onboard (self) test, so if something in the path between card and Mac is bad, nothing would show.
Sleep has been off for ages. Still is.
I’m going to try swapping thunderbolt busses also - when our power has become more stable here in Texas.
Thanks for the thought you put in!
PT Control intermittent connection RecRoom Avid S1, S3, Dock and Control App 2 03-07-2019 08:06 AM
MIDI I/O Intermittent connection to Pro Tools KentH macOS 4 04-25-2013 09:00 PM
intermittent firewire connection legoat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-07-2003 05:32 PM
192 loss and intermittent connection and then audible clock source WestPhillySoulzition Pro Tools TDM Systems (Mac) 0 04-07-2003 09:46 AM
