Protools LE for XP - Sound Card
I have an internal sound card on my motherboard. My sound works fine with the wave driver when i use PT LE, but when I try to set my default sound drivers to Wave driver - it does not show up as an option in the drop down list - just my default driver. If I disable the default driver in the BIOS will it then see my wave driver - or is this a problem with XP or with particular mother boards or sound cards?
Thanks, dave
Dave |
Re: Protools LE for XP - Sound Card
In order for the Digi001 to be recognized in the Sounds and Audio Deivces Control Panel, you must install Wave Driver v5.3.1.
You should only proceed with the Wave Driver installation _after_ you have installed PT LE v5.3.1. You may download both the Wave Driver and step-by-step instructions (via the “PT LE 5.3.1 Addendum” Guide) at the following link: http://www.digidesign.com/download/winup.html Brent |
Using Internal Sound card for playback Protools 10 | jwg1018 | macOS | 3 | 08-19-2013 05:17 AM |
Protools 10 playback via 24io and/or internal sound card | jwg1018 | macOS | 2 | 09-04-2012 08:54 AM |
ProTools 8 LE with M-Powered Sound Card | RuffinMedia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-24-2010 12:51 AM |
Can ProTools M-powered use My EMU 1212M sound card | mixmastaroberto | Pro Tools M-Powered (Win) | 1 | 11-15-2005 01:14 PM |
Can ProTools TDM exist with a sound card? | dpdemo | Pro Tools TDM Systems (Win) | 8 | 12-18-2003 11:51 AM |
