Using TWO Audio Interfaces?
Is it possible to use a second audio interface while using my Mbox in PT LE 6.1? I'd like to be able to run that new firewire interface thats pretty cheap from M_Audio as a peripheral tothe mbox as a cheap way of adding I/O to my setup. It would be way cheaper then buying an 002r. Possible?
www.JoshPollock.com |
Re: Using TWO Audio Interfaces?
no can do
DesertDude 1.25 Alu/1.5 ram/10.3.4 PTLE 6.4-002R-Live-Reason |
Anyone got any ideas on adding I/O for less then tradeing up to the mBox?
If you mean additional I/Os by means of getting more instruments into the MBox, you can get a mixer (say a mackie with 12 channels) and then route/submix the main outs into the 2 inputs of your MBOX. But that would mean using the Mbox as a 2-track (2 channel) input into Pro Tools LE.
BUT, at any one time, you can only have 2 inputs into Pro Tools LE. unless you get a 001 or 002/002R, there is no other way to get more I/Os simultaneously into Pro Tools LE. Besides, the M-Audio Firewire device you mentioned is actually a 2 input device also, although they mentioned "4" ins. It can only take 2 input at a time (either line in or mic in or SPDIF, I believe)
:: TWO ROOMS pte ltd :: Audio Post Production :: for Film / TV / Radio / Internet / Multimedia :: www.tworooms.com |
Connecting 3 Audio Interfaces to HD3 | lukeyy | Pro Tools TDM Systems (Mac) | 3 | 12-31-2010 11:17 AM |
Audio Interfaces | barry1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-15-2010 05:53 AM |
m audio interfaces | badda | Pro Tools M-Powered (Mac) | 1 | 03-28-2007 11:09 PM |
Trying to use two Audio Interfaces on one Mac | Rge | General Discussion | 0 | 03-10-2004 07:06 AM |
mix 24/nt audio interfaces | Slypolk | Pro Tools TDM Systems (Win) | 1 | 03-05-1999 08:11 AM |
