mix 24/nt audio interfaces
Will the 882/16 work with the mix24?
Re: mix 24/nt audio interfaces
Slypolk--
Sure. PT24 MIX (Mac or NT) supports the 888|24, 882|20, 888, 882, and ADAT Bridge interfaces. Keep in mind it does not support the "882 Studio" interface. The converters on the 882 are actually 18-bit in both directions, so you'll get 18-bit performance if you're in a 24-bit session. Also, the 2 SPDIF's on the 882 can pass 24 bits, so if you had an external 24-bit A/D and D/A converter you could get 24-bit signals in and out of PT. Hope this helps... Ted B. Digidesign |
Connecting 3 Audio Interfaces to HD3 | lukeyy | Pro Tools TDM Systems (Mac) | 3 | 12-31-2010 11:17 AM |
Audio Interfaces | barry1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-15-2010 05:53 AM |
m audio interfaces | badda | Pro Tools M-Powered (Mac) | 1 | 03-28-2007 11:09 PM |
Trying to use two Audio Interfaces on one Mac | Rge | General Discussion | 0 | 03-10-2004 07:06 AM |
Using TWO Audio Interfaces? | Shelob9 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-21-2003 05:19 AM |
