Old 12-16-2006, 08:00 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default Mbox 2 Firmware v1.43 - DAT Issue Fix
Firmware updaters available for PowerPC Macs, Intel-based Macs, and Windows XP:
http://www.digidesign.com/index.cfm?...4&itemid=24364
The folowing issue is fixed with Mbox 2 Firmware Updater v1.43 for Mac OS X and Windows XP:
Fixed: Certain DAT Decks Lock To The Wrong Sample Rate When Recording From Mbox 2 (Item #83265)
  • When attempting a 48kHz sample rate DAT recording via the S/PDIF input, some DAT machines would either show a clock error or lock at a 44.1kHz rate, resulting in a DAT recording that would later play at the wrong speed.
Mbox 2 with firmware v1.43 is backwards compatible with any version of Pro Tools LE for Mac OS X and Windows XP that supports the Mbox 2 (Pro Tools LE 6.8.1 and higher).
Administrator
Firmware Issue MBOX pro AVID will charge for repair flautista FireWire & USB Audio Interfaces (Mac) 0 11-07-2013 03:21 PM
MBox Pro 3 constant firmware update issue (w/ a twist...) leftalive macOS 3 04-10-2013 02:56 PM
Command 8 Firmware issue Sixstringer7 ProControl, Control|24, Command|8 0 11-18-2009 08:11 PM
002 firmware issue albee1952 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-17-2009 01:19 PM
Mbox 2 Firmware v1.43 - DAT Issue Fix Avid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-20-2006 03:32 PM
