#21
Re: Tablet PC or iPAD
Ok, thanks. For some reason I thought that in order to use one of the VNC programs available for an ipad, I had to have an internet connection to remote control a computer. Thanks for the info!!
#22
Music business is serious business. |
#23
Sorry guys, now I'm even more confused, HA! Thanks for your patience. So from the previous reply, are you saying that I can directly control the console from my laptop or from my ipad? I know that I can connect via wired or wireless to the console with my laptop, but I am wanting to leave the laptop at FOH so I can continue to multitrack the show, and mix while walking around with my ipad. I think the more precise question is this, can I remote control my laptop that is connected to my console, wirelessly with my ipad, without internet? Again, sorry I am so confused by this, but thanks ahead of time for helping me work it out!!
#24
It's not as tricky as your thinking it is...
With your laptop, you use a VNC client to connect to the console. You use the IP address and password of your console to achieve this. You can do this exact same thing with your iPad. No computer necessary. You can leave your computer at the console, to track with. Then you can take your iPad and connect it to your console in the same fashion as you do your computer... With a VNC client. Then from your iPad you log in with the IP and password of your console... If your connecting with your computer just fine, then this should be painless. Connect your iPad in the same way. The networking in place will stay the same. An internet connection isn't necessary... But like someone said earlier, don't confuse 'network' and 'internet'... Does that help? |
#25
I'm not 101% sure about this, so please correct if I'm totally lost=)
#26
Hi Guys,
I'm hoping you can help me. I have a SC48 and a Ipad with Iteleport. I can connect the Ipad to the console. I can't control anything. When I zoom in on the screen no adjustments can be made. I figured out that I need two contact points to keep the screen from moving around in zoom mode. I have watched a couple of videos of my setup. It seems to work fine. What could I be doing wrong? Thanks |
#27
Had the same problem for a bit. Found out that you have to double tap the screen on the fader or knob you want to edit, hold your finger down on the ipad, and then move it. That's the only way the ipad knows you are editing something on the SC48 and not just wanting to move the screen around. Good luck!! Chris
Chris Hunt McKinney, TX SC-48 3.0/ ProTools 10 / Mac Book Pro 13" i7 / Limelightband.com
#28
Thanks Chris,
I will try it. |
#29
Make sure teleport is on touch screen mode with the rotation lock on the correct side.
#30
Double tapping did the the trick. Worked great.
Thanks! |
Control the Eleven Rack from an iPad/Android Tablet - Video | Benoni | Eleven Rack | 8 | 10-09-2012 08:46 PM |
Tablet PC/Ipad - Pro Tools | StudioMongoose | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-24-2011 11:28 PM |
Apple Ipad tablet unveiled | nst7 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 04-21-2010 05:23 PM |
Apple Ipad tablet unveiled | nst7 | Pro Tools TDM Systems (Mac) | 18 | 01-29-2010 04:54 PM |
