  #21
Old 01-23-2010, 06:10 PM
dstagl dstagl is offline
Default Re: 2.8.1 Standalone Won't Install/Run
I just changed laptops and now am running 64-bit Windows 7 Pro under Fusion. I was having a little bit of trouble getting the standalone to work. Solution that worked was to change the compatibility mode to XP Service Pack 2.
Dave
David Stagl - Mixer | FOH Engineer
http://www.staglproductions.com
http://www.goingto11.com
  #22
Old 01-24-2010, 07:43 AM
Jaakko Savela Jaakko Savela is offline
Originally Posted by pointblankmusic View Post
After hours and hours....
...let me know if this fixes your issues and are willing to open up D-Show Standalone V.2.8.1.
-Mike
Hello Mike,
Works great on 10.6.2 / Parallells 5 / Win 7 Pro
Thanks alot,
Jaakko
  #23
Old 04-08-2010, 08:08 PM
lscroggin lscroggin is offline
i'm having the same issue. Did we ever figure out a solution to this? Thanks
  #24
Old 04-10-2010, 11:28 PM
pointblankmusic pointblankmusic is offline
I found a fix.. Look at second page of this forum under pointblankmusic... I posted instructions for several different computer configs.. Check it out and let me know if this fixes your issues..
-Mike-
  #25
Old 04-11-2010, 03:33 PM
I don't know what all that did but it's working now so thanks "pointblankmusic" I really appreciate it!
  #26
Old 04-14-2010, 09:33 AM
Axcess Axcess is offline
Thanks Pointblankmusic for all your instruction, it work very well with my Macbook with parrallel 5 and windows XP
Rémy
Venue D-Show, Ver. 3, 5x DSP card
  #27
Old 04-22-2010, 05:56 PM
Jereco Studios Jereco Studios is offline
Thumbs up Re: 2.8.1 Standalone Won't Install/Run
Mike @ Pointblankmusic
Nice job with the fix.
I had the exact same error on a dell computer and on another self-built computer. Each computer is running WinXP 32-bit SP3. After following your instructions starting with section 1a, I was able to load the software. I am very PC savvy in general, and pride myself on finding fixes to the most random of errors. +1 for you.
Avid, take notes.
Cheers,
Jeremiah
  #28
Old 05-07-2010, 08:12 AM
lakeerie lakeerie is offline
I had same problem with Parallels 5. Before instaling Venue standalone software put Mac OSX instalation DVD into CD-DVD ROM. Parallels will instal some drivers and when finished you will see in bottom corner little BootCamp logo.
Now you are ready for D-show standalone software instal.
Filip Janacek
  #29
Old 06-28-2010, 07:58 PM
Mauro Pallone Mauro Pallone is offline
Hello.
When i installed the Venue D-show system, always happened an error.
This error was similar to this other
68.591 D-Show Process ShellApp 2.8.1.77 9/14/2009 started Mon, Dec 21 2009 at 0:10:49.
68.593 Physical RAM: 2047 MB, Available: 1769 MB, Load: 13%
68.596 Plug'n'play complete.
69.587 Starting: "C:\Program Files\Digidesign\D-Show\GUI.exe"
69.607 Message filtering running!
69.713 The process 'GUI.exe' can not be started!
73.372 REPORT >>> Failed Verify! Dec 21 2009 @ 0:10:54 'StartSupervisedProcess(index, showTerminal)' failed in .\ShellAppMain.cpp(918).
73.373 Free RAM: 1769 MB, Page File left: 2548 MB, Load: 13%, GDI Objects: 22, User Objects: 6.
73.373 Now closing all processes...
73.373 DataModel did NOT save its data.
73.373 Some process didn't die in time: let's clean up the mess!
73.399 GUI.exe was gone...
73.414 End of message filtering
73.415 End of 'D-Show Process ShellApp' Mon, Dec 21 2009 at 0:10:54.
I try unistalling many times and intalling again, but it not worked.
This error persisted many times, until I downloaded the Microsoft Windows Automatic Updates. I downloaded all abailable. (not internet explorer and similar).
After download i can run the D Show Software without problems.
I have a Toshiba Satellite Pro L300 SP5801 with XP SP3.
Mauro Pallone.
  #30
Old 06-29-2010, 12:30 AM
digibase digibase is offline
So its with the Microsoft C++ and stuffs to work with D-Show.Right ?
Really appreciate Mike for the effort he has taken.
D-Show standalone install problem jwilkens VENUE Live Sound Systems 1 03-09-2012 09:11 AM
First install of Pro Tools 9 - Logic 9 already installed - PlugIn install questions b-pole macOS 2 08-31-2011 07:23 AM
Mbox 2 standalone, which drivers to install meliza11 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-20-2011 09:09 AM
Can't install Pro Tools 8! Clean install, new system, Vista! DJ Hellfire 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 31 01-09-2011 11:16 AM
6.4 install question is possible standalone flautista 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-16-2004 09:46 AM
