Correct Order to Power Up & Power Down Digi 002 Rack?
I got my Digi 002 Rack today, fired it up and it works great. Other than the initial turning on, which specified that the computer be turned off, is there a correct sequence to power up a laptop and the Digi 002 and then power them down? This is my first experience with Firewire. Can it just be plugged in hot when the laptop is already on like the Mbox can be, or should all connections be made before anything is powered on and then the Digi 002 and then the ibook?
What a wonderful piece of gear! Plugged in the ADA8000, set the clock in PT to internal and it works like a charm. Thanks, bilco |
Re: Correct Order to Power Up & Power Down Digi 002 Rack?
you can always turn on and off your digi002 rack unit on any given time whether your computer is on or off. os will just prompt you that it has lost communication with your digi002 when you disconnect or turn off the unit while protools or digicore is loaded.
Please just be aware of the energy saving features of your computer, putting to sleep your computer and drive will cause protools to crash or be slow. regards, JS |
Would it be okay to leave the Digi002 permanantly switched to the on position and turn on all the gear simultaneously with a power strip? This would include a pair of KRK powered monitors.
Thanks, bilco |
I wouldn't recommend that dude. I turn everything off 1 at a time except my Mac. My power up is this:
1. Mac always on 2. KRKs 3. 002R 4. Glyph GT050Q 5. ADA8000 Powering off is: 1. ejecting Glyph from Finder 2. Glyph 3. ADA8000 4. 002R 5. KRKs I figure it's better to let the capacitors in all the components release their stored power in succession instead doing it all at the same time. Just my $.02.
Mac Pro Dual Quad 2.8Ghz 2008 MacBook Pro i7 2012 OSX 10.8.5 - OSX 10.7.5 Pro Tools 10.3.7 - 11.1.2 6GB RAM Universal Audio Apollo Quad!!! Eleven Rack Focusrite Octopre MKII Yamaha HS80s Rockit RP5 Monitors w/ RP10 sub |
bilco |
The reason digi advise you not to turn on the 002 when the mac is powered up, and belive me it does happen, is that there is a risk of frying your mac FW port. So the best practice is to turn on the external FW devices first and then your mac. Monitors should always be last on first off for obvious reasons.
Cheers
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
Derrkins GuyBarTola ******************** PT 2018; Nuendo 8.?; Studio One 3; former Sonar and Sequoia user .... GENELEC 1031A, AVANTONE MIX CUBES (Active); Sibelius 7.0; Dorico; Mac Mini 2.6 GHz Core i7, OS X 10.12.2 Sierra; 16GB RAM; 480 GB System SSD; 1 TB 7200 rpm Audio; 3 TB samples; Roland A-800 Pro controller; GOOD BYE PEE SEA!! |
I always power up my External Hard drive, then My 003R, Then my Mac, to turn off eject the external then shut it down then shut down the Mac then the 003R.
Stay true to the sound,Less is best |
M BOX 3 Mini Correct Order POWER UP/DOWN | sunmedia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-12-2011 09:13 PM |
Power Converter for DIGI 002 RACK (US>EU) | kedilo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-26-2008 07:46 AM |
digi 003 rack won't power | ssack | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-02-2007 01:56 AM |
Power consumption of Digi 002 rack? | rsgilbert3 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-22-2006 01:19 PM |
002 rack power harness power suplly issue | rockstah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-06-2004 11:04 PM |
