Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 04-09-2018, 01:04 PM
Matt Darcy Matt Darcy is offline
Default Mackie Active monitor - 1 speaker huge white noise
I recently got myself a new desk, and as a result had to remove everything from my old, get the new one in and re-wire.
I've got a pair of Mackie H264 MKII that I've put back on the desk and plugged power in. The left one is fine, the right one as soon as I power it on has a huge white noise sound coming from it. it has no input plugged in, and I've tried two IEC cables into two different wall power sources and through a Samson powerbrite power strip.
I'm in the UK so get good power, I'm guessing the right speaker is somehow damaged, it looks visually fine and I was careful moving it, but for one speaker to just make this noise with no input worries me. Suggestions ?
thans.
Old 04-09-2018, 07:05 PM
Default Re: Mackie Active monitor - 1 speaker huge white noise
Does the volume control work? If so, turn it down all the way, plug in some signal and bring it up slowly and see what happens. Sure sounds like it bit the big one
Old 04-11-2018, 01:37 PM
I managed to figure out by chance one of the switches had a bit of dirt in it, and hadn't quite gone fully across, blast of air and flick the switch and all is good. Sorry for the panic.
Old 04-11-2018, 07:34 PM
That's some good detective work
White Noise, distortion, pops, loud noise in Pro tools 9 and mbox mini Bigpit Windows 1 09-09-2013 09:26 AM
Pro Tools 10/Mackie Onyx white noise in record mode benbeer macOS 3 02-21-2013 07:27 PM
weird (not white noise) in right speaker in any app paul5mq 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-12-2009 02:13 PM
MBox Monitor levels and white noise on playback Zaxxon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-03-2004 10:41 AM
MBox Monitor levels and white noise on playback Zaxxon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-01-2004 01:35 PM
