Old 09-28-2020, 06:51 PM
Default Re: Playback Engine not seeing HD Native Omni
Bit of a mystery
What does Digitest say?
Did you upgrade macOS? As a part of this upgrade? Was that an in-situ? or a clean install?
When you installed Pro Tools did you get a security warning about installing the driver? And did you acknowledge that??? ... I can't see how you could not as the kext should be loaded OK for System report to identify the device.
I would
Trash prefs
Reboot your computer
Still does not work... Especially if you did an in-situ macOS upgrade, start over with a clean macOS install on a spare drive or container. Install the bare minimum stuff and Pro Tools just to see if it works. Even if you did not do a recent install, I might just try this. Make sure any security related pop-ups get dealt with during the install.
Old 09-29-2020, 12:49 PM
rabinrocks rabinrocks is offline
I'm starting to think it might have something to do with the Thunderbolt 3 (Usb C) ports on my MacBook Pro. I installed Pro Tools Ultimate on an old MacBook Air and although I had to trash a couple things and reinstall the driver it did recognize the HD Native Thunderbolt (The MacBook Air also has a Thunderbolt 2 input). I went back to the MacBook Pro and did the same trashing/reinstalling and still nothing. Apple after troubleshooting thinks it's a software problem as it is seeing the HD Native Thunderbolt as being connected to the MacBook Pro Thunderbolt 3 (Usb C) port.
Old 09-29-2020, 05:32 PM
:-O
I would
Trash prefs
Old 04-26-2021, 02:40 AM
johnrobertwood johnrobertwood is offline
Was this ever resolved? I'm having the same issue - HDX playback engine is not an option. I've installed the driver carefully (no alerts from Security prefs), and Digitest reports the card working fine. Avid HDX is present in Audio Midi Setup, and I can play system audio thru the interface. The only thing missing is being able to select the playback engine in ProTools
Mac Pro (2019), 3.2GHz 16-core, 160GB/8TB
macOS 10.15.5
Pro Tools HDX 2020.3.0, UAD Octo
Old 04-26-2021, 06:42 AM
creativecontrol's Avatar
It sounds like the workstation and macOS both recognize your Avid hardware. I presume you are running Pro Tools Ultimate and have a valid iLok authorization for the DigiLink IO license, yes?
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #16
Old 04-26-2021, 06:50 AM
What interface is connected to the HDX card?
HD Native I/O does not show in playback engine Kevn Blvk Pro Tools HDX & HD Native Systems (Win) 5 12-31-2017 12:50 PM
HD OMNI not showing up in Hardware / Playback Engine Tab. rpmprod Pro Tools HDX & HD Native Systems (Mac) 3 01-20-2017 03:25 PM
HD Native Thunderbolt /OMNI -Initalizing Audio Engine HANG GrahamB Pro Tools HDX & HD Native Systems (Mac) 9 04-20-2016 11:03 AM
No HD Native option in Playback Engine select ronstephens Pro Tools HDX & HD Native Systems (Mac) 9 07-02-2015 09:16 AM
PT 9.0.5 Native has problem with playback engine JoeM Pro Tools HDX & HD Native Systems (Mac) 2 12-04-2011 06:08 AM
