192 I/O line level or mic level inputs?
I am using some outboard gear hooked up through 1/4" patchbays. I sometimes route as a hardware insert in PT. Sometimes I'll use something between pre and converters. The 192 output of pro tools (db25 -> 1/4" patchbay) and 192 input (1/4" -> db25 from patchbay). I am connecting to outboard (EQs/compressors) from patchbay using 1/4" -> xlr (inputs of outboard), and coming back from outboard outputs xlr ->1/4" patchbay. Does this make sense?
I just read info on Warm Audio's website stating that coming from WA2A leveling amplifier should output 1/4" line level to interface. Am I accomplishing that the way I am using it in my studio? I haven't run into any problems, but fundamentally, am I screwing up? Thanks for any help!
Producer/Engineer/Studio Owner/Published composer Mac Pro [OS X 10.10.5, 3.7 GHz quad-core, 32 GB memory], PT 11 HD, 192 I/O with HD Native |
Re: 192 I/O line level or mic level inputs?
192 is line level.
Mic level would be way, way lower. For the 192, you still have options for input levels (+4 or -10), but the output is fixed at +4. And you really should use the input as +4 to keep the gain staging consistent.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 Last edited by BScout; 03-22-2018 at 07:16 PM. Reason: clarification for which box |
AFAIK, the WA2A ins and outs(both XLR and TRS) are the same line level so you can use either connection to suit your cables. In any case, the 192 is a line level unit(except for the 192 DIGITAL)
Thank you guys for the info! It straightened me out!
003 Rack DI inputs as line level | littlegreenmen13 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 01-28-2012 01:42 PM |
Inputs 1-4 used as line-level on 003 Rack | Everything | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-23-2007 06:34 AM |
ProjectMix 1/4" Inputs Truly Line Level ? | 2012 | Pro Tools M-Powered (Win) | 0 | 07-05-2006 09:10 AM |
002 - can't get decent record level on line inputs | swiman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 03-11-2005 02:22 PM |
Digi 001's line level inputs 3-8. Control input? | dcarlson247 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-26-2001 02:04 PM |
