Old 01-28-2009, 11:05 PM
Oroz Oroz is offline
Default Latch Record Enable Buttons on all type of tracks?
I can figure out if there's a way that the "Latch Record Enable Buttons" function will work with every type of channel. This function is only working with the same type of channels but I want to be able to record enable a track regardless of its type and that ONLY that channel is record enable.
Old 02-04-2009, 10:16 PM
Default Re: Latch Record Enable Buttons on all type of tracks?
Or is there a shortcut where you can record enable just the track that you want to record in and disable every other track?
Old 02-05-2009, 02:38 AM
del cosmos del cosmos is offline
You mean midi and audio?
Old 02-05-2009, 09:29 AM
Yes, I mean MIDI and Audio. So far the function is only working on the same type of tracks, for example, if I have an audio track that's record enabled and then I record enable a MIDI track both tracks get record enabled instead of just one.
I would like to be able to record enable any track and that regardless of is type only that track gets enabled.
Old 07-14-2009, 01:03 PM
balters balters is offline
i've got the same problem when recording audio then midi and vice versa...found myself recording over tracks... has anyone found a way to do this?
thanks in advance
Old 07-14-2009, 02:04 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
There isn't... U just have to stay cautious & take a midi track out of record after u record ur midi if u know ur done with it... Or undo will be ur fave function
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 07-31-2020, 05:16 PM
SomeOtherGuy SomeOtherGuy is offline
Still waiting for this fix...
Pro Tools Ultimate, Avid MTRX, MOM, MacBook Pro 16 (2023) 96 GB RAM, Mac OS Ventura, Samsung SSDs
Record Enable Tracks chuckgreenjr Pro Tools 10 6 05-31-2012 08:33 AM
Latch Record Enable doesn't work jsmit72 Pro Tools 9 0 01-17-2011 11:03 AM
No Record Buttons for Aux Audio In Tracks! bromichael Digidesign Hardware & Software 3 12-21-2004 04:40 PM
how to record enable bunch of tracks at once? LEVON 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-19-2002 01:58 AM
Latch solo buttons Zownd Pro Tools TDM Systems (Mac) 0 04-27-2002 06:20 AM
