Old 10-20-2012, 07:24 AM
bonfire bonfire is offline
Default Headphones work while recording but not during playback
Well, usually it's the other way around, but my headphones work during recording, but I can't hear anything during playback. The level meter is going, so the audio was recorded. It's just not coming through the headphones.
I recently lost my previous hard drive (PT worked fine then) and have started fresh with a totally clean new hard drive. I don't think the new drive has anything to do with my problem though, since I'm getting sound out of the headphones during recording.
Thanks for any help.
Old 10-21-2012, 01:08 AM
Lincoln Mitchell Lincoln Mitchell is offline
Default Re: Headphones work while recording but not during playback
Welcome to the forum...
The reason you have 124 looks and no answer is because you haven't told us jack about what you are using or have done to try and fix it...
Check out the help us help you up there ^^
More than likely you are using an mbox with the mix knob turned all the way to input...
Lincoln Mitchell
Pro Tools 2018.10
Mac Mini Server. 10.13.6, 16GB Ram, SSHD
Apogee Ensemble Thunderbolt, Apogee Element 24
Presonus StudioLive 24 and 24R Series III
Presonus Digimax DP88 ADAT
Distortion all over(recording tracking playback) But it Did work yesterday!! stokes17 Pro Tools M-Powered (Win) 3 08-20-2010 10:25 PM
After recording, Playback will not work. jared.austin.snedden 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 10-29-2008 01:06 PM
Playback only through headphones! jikaru 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-10-2008 07:51 PM
Playback in the headphones felix822 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-12-2007 03:33 PM
No Playback through Headphones kucharo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 10-04-2001 11:12 PM
