EQ Gain In Vs. Gain out
Hello,
Can someone please explain me the difference in "gain staging" with the gain in and gain out on my EQ's? Thanks. |
Re: EQ Gain In Vs. Gain out
That depends on what eq we are talking about, in the eq3 it's probably no difference apart from the position in the signal path but maybe in some analog modeling eqs the input signal can be pushed into the circuit to generate the saturation characteristics of that particular hw. The output level is usually a volume control to match the level to unity after the changes of energy introduced by the frequency boosts and cuts.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
Hi, Thanks.
So that means that if I'm using the EQ3 7-band, I should probably be using the output gain after cut/boost for gain staging? |
Welcome to the community!
The idea of staging is to maintain the level hitting the 2 bus at a certain db, usually -12 to -18. so depending on how many plugins and what each is going to add(which can vary wildly), you lower or increase input or output gain of each to total your target. If its just normal subtractive eq, you might need to add some output gain. On the other hand , any thing with saturation or "analog" (adds harmonics) will often need the input or output or both gains lowered, especially if you are using more plugs after, say a compressor or tape delay sim. The total to the bus is the target, preventing clipping in each plugin along the way by watching the ins and outs db.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro PT 2023.3 Studio through an A&H Qu-32 |
U R correct. I have found that some plugs perform differently depending on gain settings, so I tend to use the analog rules even in the digital realm. I agree that it isn't necessary in most cases. I didn't make that clear
Clip gain o Gain plug in | Camilo Toledo | Foro en Español | 3 | 03-22-2017 02:10 PM |
AudioSuite Gain/Normalize also on Clip Gain | A-n-d-i | macOS | 0 | 03-13-2014 12:46 PM |
Gain, level on preamp vs gain on Digi (guidelines)? | rcook349 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 10-04-2007 08:18 PM |
Can't get enough gain to PT | Imagine | Pro Tools TDM Systems (Mac) | 9 | 08-20-2004 03:24 PM |
44.1 to 48K and ... more gain?!?!? | gandalf07 | Pro Tools TDM Systems (Mac) | 8 | 07-03-2002 12:10 AM |
