Old 06-19-2018, 02:29 PM
[email protected] ckwalldorf@gmail.com is offline
Default MIDI punching not creating New Region
Hello. I just noticed this on ProTools 12 with both my HDX and Native system. When I'm punching in MIDI, it no longer puts a break on the clip when it starts recording. I get the pink bar starting at the punch point but when I stop, it combines it all into one MIDI track/region. THIS IS NOT BECAUSE MIDI MERGE IS ON. That is off and it's not merging MIDI info on top of one another. Destructive Record is also off.
It basically records on top of the previous MIDI track, but doesn't put a break so that I can't pull the previous take forward and choose my punch point. It seems like there's some Default MIDI punch option that has been selected that's recording MIDI destructively. Interestingly, if I make an break point BEFORE I start recording and then punch, I'm able to pull the previous take forward as I always have, but it no longer does it automatically. Any help would be greatly appreciated.
Thanks!
Chris
Old 06-20-2018, 12:12 AM
Stig Eliassen's Avatar
Default Re: MIDI punching not creating New Region
Welcome to the community.
MIDI recording is detructive (clips are consolidated) unless you enable MIDI Merge, or use loop recording.
Old 06-20-2018, 10:08 AM
Thanks for the response! That hasn't always been the case, though. Take the example of someone playing MIDI piano. They get 3/4 of the way through the chorus before making a mistake. I would set the punch point at the beginning of the chorus and punch them in. If I liked the first part of the chorus from the previous performance better, there would be an edit line on the clip at the beginning of the chorus where I punched them in. I would be able to take the trim tool and pull their previous performance from the punch point just as I would be able to do with an audio clip. Now, it doesn't give me an edit line at the punch point so I can't pull from the previous performance and massage the punch point. It just adds it into the clip as if it was all one performance.
Again, if you do create an edit line with Command E BEFORE you do a punch, you can do what I'm describing and pull the previous performance from underneath the new one. That used to happen without needing that extra step. It's definitely something that happened in the update. I've confirmed with two other engineers that PT 12 is set like this and that wasn't always the case. Thanks!
Old 06-21-2018, 12:16 AM
That's true. I seem to remember PT behaving as you describe. I've referenced the manual, and tested all I could think of in my studio, and MIDI recording in PT 2018 works "destructively", with a few exceptions.
creating a blank region [solved] lblanks240 Pro Tools 12 5 01-04-2017 11:41 PM
creating fade on muted region daniri Tips & Tricks 2 12-23-2006 08:45 AM
creating fade 0n region makes wierd noise bug carlos santana Pro Tools TDM Systems (Mac) 0 09-02-2006 06:10 AM
punching in on a highlighted region woodbeatz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-25-2004 04:32 AM
Creating Region between 2 Markers fader8 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-05-2003 06:45 PM
