Old 01-09-2020, 12:48 PM
rrsf rrsf is offline
Default No sound from bounced mp3 file
[solved]
Hi there, relatively new user here. I've managed to bounce sessions to mp3 before, but something is wrong today and I can't work out what it is.
I had some trouble with the I/O setup when I opened the session, and did a delete paths and default reset of the busses. Then I could hear sound through my playback engine (Apollo x4).
When I do a bounce, I've tried the Mon L/R outputs, as well as the Virtual 1/2 outputs as options, but neither seems to produce any sound in the bounced mp3. Also tried physical output and output. (Attached screenshots of the options I tried.)
Outputs for each track in the session is MON L/R. (Also attached screenshot.)
(I had Pro Tools' sound coming through on Virtual 1 and 2 on my UA Console, which is why I tried that. But took it off.)
Would appreciate any tips. TIA
my system specs:
iMac (27-inch, late 2013)
macOS High Sierra (v 10.13.6)
Universal Audio Apollo x4 Thunderbolt
Pro Tools v 2019.12
[Amount of Memory installed where?]
attached peripherals: G-DRIVE mobile USB-C (containing the PT files); G-DRIVE mobile USB for Time Machine; LG screen for extended desktop
Last edited by rrsf; 01-10-2020 at 02:52 PM. Reason: problem solved. want to make sure new readers know
Old 01-09-2020, 01:59 PM
john1192 john1192 is offline
Default Re: No sound from bounced mp3 file
hmm .. never tried to Bounce an MP3 in Multiple Mono Mode .. try interleaved maybe !!!
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD -OS 10.12.6 for PT 11.3.2 & 2019.6 last version
Logic Pro X latest version
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.14.6 - PT 2019.6 Ended here ..
RME BabyFace Pro
Old 01-09-2020, 03:23 PM
This is unlikely to have anything to do with multi-mono, which lots of people use.
The easiest way to not get sound on a bounce to disk is to not have a correct timeline selection made for when you what you want to bounce, especially to accidentally click somewhere and create a timeline selection out past the end of the session or of other silence and have that all off screen. Accidentally just toggling mute is another good one.
If that is not it...
Does realtime bounce work. That's normally a suspect if you have HDX but you don't but still an interesting question.
I don't follow all the discussion about IO setup. I can't work out if you knew for sure you have particular monitoring path working (and it was not say getting confused up with others through the Apollo console) and you were trying to bounce that exact output. The console metering should make clear what is driving what.
Still having problems make things stupidly simple: Use Built-In Output or whatever it's called on your Mac as the Playback Engine. Default all the IO. Now can you get that session to bounce OK?
Old 01-09-2020, 03:41 PM
HurtMesaMusic's Avatar
HurtMesaMusic HurtMesaMusic is offline
My first experiences with Apollo got me a few blank MP3s. Selecting another main output always fixed it. When things start working, it’s a good idea to export IO settings in Pro Tools and save settings in the Console mixer and settings.
Old 01-09-2020, 08:06 PM
Thanks for mentioning interleaved. I didn't realise that's how to get just one wav file!
my system specs:
Pro Tools v 2019.12
Old 01-09-2020, 08:11 PM
The monitoring path is now working, but I can't tell, when I select the MON option when bouncing, whether it's able to pick up the signal from there, or whether having the Virtual 1/2 is interfering in some way? On my Console, the Virtual 1/2 meter is active during playback and bounce.
Attaching screenshots of my I/O setup in case there's something there that's creating the problem.
my system specs:
Pro Tools v 2019.12
Old 01-09-2020, 08:15 PM
I had to look up realtime bounce. It turns out I've been doing realtime, and I can hear music while it's bouncing. Maybe I should try offline?
I will try this next!
my system specs:
Pro Tools v 2019.12
Old 01-09-2020, 08:16 PM
Thank you! I didn't know about exporting the I/O settings. Opening different files would sometimes change settings and I was manually changing them back...
my system specs:
Pro Tools v 2019.12
Old 01-09-2020, 08:55 PM
Tried this, and still no sound. What does that mean...?
my system specs:
Pro Tools v 2019.12
Old 01-09-2020, 10:22 PM
So you used built-in output? Defaulted all the IO (delete the paths and then click the default button). But what exact output path are you bouncing?
Try again with a new empty session. Have one track. Keep making it simple until it works. It's very likely something you are doing wrong/have messed up.
Bounced file sounds bad Gillis Pro Tools 12 8 05-12-2016 06:54 PM
Where did my bounced file go? Terry Wetzel Pro Tools 9 5 04-06-2016 02:13 PM
Beep at the end of a bounced File? serialcarpins 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-01-2008 06:07 PM
bounced mp3 file longer than source file chobbs Pro Tools TDM Systems (Mac) 4 01-24-2006 04:00 PM
clipping of a bounced file Kenn LeGault Digidesign Hardware & Software 2 12-12-2000 01:08 AM
