Re: 32 Samples H/W Buffer Size playback with 192 I/O
SiSoftware have confirmed Memory Bus Speed is reporting incorrectly in the latest version of Sandra with my rig. They're going to have me run some tests and logs and such.
Mike.
This might qualify for "the best worded, but most idiotic thing I've ever heard said" award.-ejwells Avid Pro Tools|HD Native 9.0.3. Win7x64Sp1. i7-930 X58A-UD3R. Acronis backup. Black Viper optimized. Google the DUC Search Avid |
Thanks for the update Mike. Ummm... are the previous revisions of Sandra not reporting correctly?
Aaron Mulqueen - 001 HD Native |
v1715 reports correctly.
But I wouldn't be concerned. If QPI and Uncore values are correct, the IMC will be working at the correct frequency. Mike.
Between you, me and the fencepost, I too are having trouble with 64/32 H/W Buffer Playback on certain partitions and I've narrowed the cause to a driver or programme/utility. Perhaps it might be worth taking a look in another direction.
OK Aaron, I'll admit to being the fencepost. What driver or programme/utility do you suspect? The operative word here is suspect so you won't be held accountable if it doesn't turn out to be the case. What direction should we be looking?
Greg
Intel i7 3930K, Gigabyte GA-X79-UP4 (rev 1.0), 32 GB Corsair Vengeance 1600 ram, EVGA Nvidea GT 720 TI video card, a Samsung 850 Pro (256 GB) OS drive, 2 Samsung 850 Pro's (512 GB) in externally mounted drive bays for session and sample storage, Win 10 Pro, PT Ultimate (Native)2019.10, HD Omni, HD I/O 16x16 . |
#16
Hi Greg, I'm regressing this as we speak. I'm not sure if it's a Windows .dll or a Gigabyte driver or another third party driver and utility combination. All I know at this comment is that I have one partition that does not produce -909x Playback Errors. I clone this drive and install previous versions of Pro Tools and no -909x errors display. Point is what makes that cloned partition so special. It can only be software.
#17
Mike, if you're running in SATA IDE Mode do not install Intel Rapid Storage Technology (RST) Utility/Driver. You do not need to install Intel INF Utility. And if you are running an ATI graphics card disable AMD External Events Utility. These I have found to be contributors to -909x Playback Errors and Clocking disruptions at 32 Sample H/W Buffer.
HW buffer size 64 samples..?.. | Codo | Pro Tools TDM Systems (Mac) | 2 | 11-01-2011 03:58 PM |
can't change h/w buffer size above 128 samples | mmiller | Pro Tools M-Powered (Win) | 6 | 07-24-2010 10:42 AM |
I Want H/W Buffer Size of 2048 samples on 002R | jbaby | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 12-05-2008 03:44 PM |
HELP....H/W Buffer Size @ 128 Samples or less DOENS'T WORK AT ALL | rogerhavoc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 12-31-2002 05:17 PM |
My whole system crash when i set my H/W Buffer Size @ 128 Samples or less | rogerhavoc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-29-2002 02:50 AM |
