protools hd 8.0, win7 64bit, audio driver couldn't be recongizable by windows
hi all, just switch my HD 2 from G5 to win 7, problems are listed:
protools hd 8.0 and audio driver successfully installed, protools runs allright, but asio driver couldnt be seen in windows system,no sound come out from windows media player or the other players or system. tried upgraded to 8.04, same result. asus motherboard p8z68-v, i3 2100, 2G kingstone ddr, 192/io,HD2 pci-x (process). thanks a lot for concern and looking forward to answer! |
Re: protools hd 8.0, win7 64bit, audio driver couldn't be recongizable by windows
There is no 64-bit windows audio driver in protools HD8 or HD9 so Media Player etc won't work.
I don't know about 10. The ASIO driver is 32-bit, so you can only use this with apps hat expect a 32-bit ASIO driver. So for example Cubase 32-buit and Wavelab will see the ASIO driver, but Cubase 64-bit won't..... |
There is no Windows Wave driver for PTHD 8/9/10 so you never hear windows sounds or media player etc throught your HD rig, there is an ASIO driver for 10 W7 x64 for other DAW use but no wave driver.
A workaround i use it to enable my onboard audio for windows sounds and pipe the spdiff out to my monitoring converter.
PT10HD5 PCIX in 64Bit Magma Chassis, 2x192io's + 2x96io's & Legacy io's Pro Control & Fader Pack UAD2 Quad, Octo & All Plugins Black Lion Audio Modified MOTU 24io and 2408MK3 x2 TC Powercore PCI MK2 x2 & Firewire Softube, Sonnox, Eventide, SSL, McDSP, Waves |
Digi003 Driver issue?? + Windows 7 64bit | jouleskeys | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 09-01-2011 05:20 PM |
mbox2 mini audio driver will not set for win7 | eastjeff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 08-26-2011 10:47 PM |
003rack+win7-64bit PC+digi asio driver = midi input (5pin) problem! | Slaido | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-22-2011 06:32 AM |
Installing Mbox2 Win7 64bit drivers WITHOUT Protools 8 - Have you done this? :-) | grasta | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 02-25-2011 07:23 PM |
Problems Getting Mbox 2 ProTools 8 to install on 64bit Win7 | flashmcclain | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-24-2010 01:40 PM |
