Old 07-20-2010, 08:53 AM
teacherman teacherman is offline
Default Solo Safe bug??? PT 8.0.1 cs
<command> + Solo Button brings up a tiny channel fader that covers the channel's Solo Button that gets in the way of Solo Safing a Channel.
Anyone else experiences this bug?
PT 8.0.1. cs
Old 07-20-2010, 08:57 AM
jeremyroberts jeremyroberts is offline
Default Re: Solo Safe bug??? PT 8.0.1 cs
PT 8.0.1. cs
no.
I can command-click on solo button in either mix or edit windows. Works exactly as it should.
PTHD 8.0.1cs2
PPC
sorry.
--Jeremy
Old 07-20-2010, 09:02 AM
The problem is only local with the current session that I am in. I re-opened several other sessions and the Solo-Safe works perfectly.
Apparently, kind of weird/odd preference has been enabled that is causing Solo-Safing to be disabled.
Any Clues?
Okay...also...I just created a New Session to see if the problem followed and Yes...Solo-Safing is being Blocked in All New Sessions.
Old 07-20-2010, 09:15 AM
Okay....Just figured out what the problem is.....
The session's SOLO MODE (under Options Menu) was not set to S.I.P.
All better now.
later.
solo safe mikeyman Pro Tools 10 14 06-10-2013 09:19 AM
Protools 10: mute and solo aren't working. (Solo safe is not on any of the tracks.) charlottewrinch macOS 2 04-14-2012 05:32 PM
Solo/Solo-Safe dilemma xcevinx Pro Tools 9 10 12-08-2010 07:12 AM
what is solo safe cyndiek 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-02-2009 11:10 PM
"Solo Safe" problem teacherman Pro Tools TDM Systems (Mac) 2 09-08-2006 06:48 PM
