Old 06-16-2008, 01:07 AM
chili1222 chili1222 is offline
Default Error: Channels 0/0 could not be set on ASIO driver
hi,
i know most of you guys are using protools, however, i hope u guys can give me some clues regarding to the digi 001 and cubase sx 3.1.1.
basically, i used to use digi 001 with cubase sx 3.1.1, the driver installed was ASIO digidesign 6.1.1 driver, it works perfectly. however, when i tried to install the whole DAW onto my new pc and select the asio digidesign driver from cubase's device setup, it comes up with the error of "channels 0/0 could not be set on asio driver asio digidesign driver". when i go and check the missing hardware, it didnt come up with anything and it actually said that the digi001 was working properly.
Actions i've done:
window xp with serivce pack 3
window xp without service pack 3
un and re install asio drivers, cubase and window xp.
disable onboard soundcard, delete onboard soundcard drivers
clear all error registers
does anyone has any ideas?? please help, thanks
brian
Old 06-16-2008, 07:33 AM
spkguitar's Avatar
Default Re: Error: Channels 0/0 could not be set on ASIO driver
The whole DAW?? Do you mean the Pro Tools software? What version of the software are you trying to use? (The only version that is going to work for the 001 is 6.4).
You cannot have the standalone drivers and the drivers from the install disk installed at the same time.
You need to:
  • Download the Pro Tools Uninstall Utility
  • Run it
  • restart
  • install only one of the hardware drivers, either the standalone drivers, or if you are also going to use Pro Tools then only the Pro Tools software with the ASIO drivers selected on install.
Old 06-16-2008, 08:21 AM
hi spkguitar,
i only install the asio driver, didnt install the protools
btw i also tried:
digi MME helper
asio digidesign driver 7.1
anything else i can do???
Old 06-16-2008, 08:39 AM
spkguitar's Avatar
then what did you mean when you said this?
What "whole DAW" were you referring to? It would help if you could be a little clearer...
btw i also tried:
digi MME helper
The MME helper has nothing to do with the ASIO driver.
That was definitely a mistake. As I said earlier, the 001 will not work with the new drivers at all. Having the new drivers installed at all will overwrite many of the old components and cause the ASIO driver to malfunction with the 001.
My earlier recommendation stands:
You need to:
  • Run it
  • restart
The standalone version of the ASIO drivers that you need to be using is 6.1.1
Old 06-16-2008, 09:48 AM
hi spkguitar, thanks for your quick reply and comments
i think my bad writing misunderstood you. sorry about that. the whole DAW i mentioned earlier means only digi001 hardware, asio digidesign driver 6.1.1 and cubase sx3.1.1 (no other asio drivers, recording software e.g. protools were installed)
asio 7.1 driver and mme helper were installed after i encountered the problems
the reason i installed the mme helper was because someone suggested to do that although i understand it only help with the wave digidesign driver. i also understand the asio 7.1 driver doesnt work with 001, however, being without any clues and further suggestion, i had to give it a try. just wanna try everything possible.. its sad to say that
i hope all the pros out there could help me. really thanks for that, cheeers brian
Old 07-02-2009, 03:13 PM
volanto volanto is offline
Banned
Hello every one
I have the exact same problem! i used to use my Mbox 2 with Pro Tools 7.3, Ableton Live 7.2 and Cubase SX3! All three of them used to work fine. since then i have formated and reinstalled windows with everything but for a while i did not have Cubase installed. earlier today when i installed Cubase again, i wanted to check the Digidesign driver in the 'device setup' in cubase' and walla it gave me the exact same message! i was dead confused because it used to work just fine.
any help please!!
Old 07-03-2009, 09:21 AM
Banned
anyone?!?! i need to have it working by next week!! help!!!
Old 07-03-2009, 09:59 AM
sw rec sw rec is offline
help!!!
Not without a system report, and anyway, it's best to start your own NEW thread....
FL STUDIO 7 ASIO DRIVER ERROR.VISTA[PT 7.4 L3] vetsquad muzik General Discussion 4 01-10-2011 08:42 AM
PT9 - 003 rack -ASIO DRIVER error with Cubase 4.5 - any solution? Kev79 Pro Tools 9 4 11-15-2010 01:24 AM
DIGI ASIO DRIVER PROBLEM WITH FL 8 "Not Enough ASIO output channels available. scottthafoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 04-19-2010 01:45 PM
Mbox 2 Pro & Cubase SX3 (Asio driver error) Metroid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-08-2009 07:37 AM
FL7 PRO TOOLS 7.4 LE[ASIO DRIVER ERROR IN FL7. vetsquad muzik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-17-2008 08:06 AM
