Old 03-28-2009, 04:30 PM
shakuhachi2 shakuhachi2 is offline
Post Strange Install Prob - PT mp on XP system
I'm having no luck in installing ProTools 8 on a brand new system. I'm experiencing some symptoms similar to that reported by a few LE users recently.
After a clean OS install, updating my Maudio 2496 drivers, & the iLok drivers, and Quicktime, I run the installer without any apparent problem. But when I launch protools the program hangs in launch, while appearing to be loading structure.dpm. But if I remove structure components from the plug-ins folder it will then hang on Xpand!.dpm, and if I then remove Xpand! components it will then hang on VariFi.dpm, and so on...If I rename the plug-ins folder plug-insX, and create an empty folder called plug-ins, a tactic suggested by tech support in a phone consultation, the program will hang as soon as it begins "loading Plug-Ins." I have uninstalled and reinstalled PT. I have reimaged my system disk from Ghost, installed all new up-to-date drivers and so forth, all to no avail. Any further tactics or strategies anyone might suggest would be appreciated.
Joel
Here is a Sandra Report on my system
***** Start of Report *****
<<< Server Status >>>
Name: SiSoftware Sandra Lite [Evaluation] (x86)
Version: 2009.1.15.72
Copyright: Copyright © SiSoftware Ltd 1995-2009. All
Rights Reserved.
Registered Owner: Joel Taylor
Licence Status: Evaluation copy, strictly for personal/
educational use only. For business/commercial
use, it can be trialled for 21 days.
Licence Extra: You are on day %i of your evaluation period.
Please see the SiSoftware site (http://
www.sisoftware.co.uk) for purchase details.
URL: http://www.sisoftware.net/sandra/
E-Mail: sandra.soft@sisoftware.net
User: Joel Grant Taylor
Host Name: GONGAGENG
System ID: {6B3A1DBF-34F6-4F8B-886D-F52D9FAEC450}
Run ID: {4B31709D-527A-4671-BD48-12D622DEF21C}
Date: Saturday, March 28, 2009 @ 1:28:53 PM
<<< Report Comments >>>
Comments on report: This Sandra report was created 3/28/2009 on a
system that is having difficulties launching
Protools. There is no other proaudio
software installed. --jgt
<<< Computer Overview >>>
< System >
Workgroup: WORKGROUP
< Processor >
Model: AMD Phenom(tm) 9600 Quad-Core Processor
Speed: 2.31GHz
Cores per Processor: 4 Unit(s)
Threads per Core: 1 Unit(s)
Type: Quad-Core
Internal Data Cache: 4x 64kB, Synchronous, Write-Back, 2-way,
Exclusive, 64 byte line size
L2 On-board Cache: 4x 512kB, ECC, Synchronous, Write-Back, 16-
way, Exclusive, 64 byte line size
L3 On-board Cache: 2MB, ECC, Synchronous, Write-Back, 32-way, 64
byte line size, 4 threads sharing
< System >
System: System manufacturer System Product Name
Mainboard: ASUSTeK Computer INC. M3A78 PRO
Bus(es): ISA PCI PCIe IMB USB i2c/SMBus
Multi-Processor (MP) Support: No
Multi-Processor Advanced PIC (:Yes
System BIOS: American Megatrends Inc. 0801
Total Memory: 2GB DIMM DDR2
< Chipset >
Model: AMD (ATI) RS780 Host Bridge
Front Side Bus Speed: 1x 201MHz (201MHz)
< Chipset >
Model: AMD (Family 10h) Athlon64/Opteron/Sempron
HyperTransport Technology Configuration
Front Side Bus Speed: 2x 1.81GHz (3.62GHz)
Memory Bus Speed: 2x 335MHz (670MHz)
< Memory Module(s) >
Memory Module: Kingston 2G-UDIMM 2GB DIMM DDR2 PC2-5300U
DDR2-666 (5.0-5-5-15 3-20-5-3)
< Video System >
Adapter: ATI Radeon HD 4350 (512MB, PCIe 2.00 x16,
PS3.0, VS3.0)
< Graphics Processor >
Adapter: ATI Radeon HD 44XX (RV710) (1.03, 512MB,
600MHz/250MHz)
< Storage Devices >
WDC WD1500HLFS-01G6U0 150GB (S:140GB (C:)
WDC WD1500HLFS-01G6U0 150GB (S:140GB (D:)
ASUS DRW-22B1LT (SATA150, DVD+:N/A (E:)
< Logical Storage Devices >
Hard Disk (C:): 140GB (NTFS) @ WDC WD1500HLFS-01G6U0 150GB
(SATA300, 10000rpm, NCQ, 16MB Cache)
Data Disk (D:): 140GB (NTFS) @ WDC WD1500HLFS-01G6U0 150GB
CD-ROM/DVD (E:): N/A @ ASUS DRW-22B1LT (SATA150, DVD+-RW, CD-
RW, 2MB Cache)
< Peripherals >
LPC Hub Controller 1: ASUS IXP SB600 SMBUS Controller
LPC Hub Controller 2: AMD (ATI) SB700 LPC host controller
Audio Device: ASUS IXP SB600 High Definition Audio
Controller
Audio Codec: Realtek Semiconductor 888 High Definition
Audio
Audio Device: ASUS RV730XT Audio device [Radeon HD 4670]
Audio Codec: AMD (ATI) AA01h
Serial Port(s): 1
Disk Controller: ASUS SB700 SATA Controller [IDE mode]
Disk Controller: ASUS SB700 IDE
USB Controller 1: AMD (ATI) SB700 USB OHCI0 Controller
USB Controller 2: AMD (ATI) SB700 USB OHCI1 Controller
USB Controller 3: AMD (ATI) SB700 USB EHCI Controller
USB Controller 4: AMD (ATI) SB700 USB OHCI0 Controller
USB Controller 5: AMD (ATI) SB700 USB OHCI1 Controller
USB Controller 6: AMD (ATI) SB700 USB EHCI Controller
USB Controller 7: AMD (ATI) SB700 USB OHCI2 Controller
System SMBus Controller 1: AMD IXP SMBus
System SMBus Controller 2: AMD AFS SMBus
< Printers and Faxes >
Printer: Lexmark X74-X75 (600x600, USB, Colour)
< Scanners and Cameras >
Scanner: Lexmark X74-X75 (USB)
< Network Services >
Network Adapter: Realtek RTL8168C(P)/8111C(P) PCI-E Gigabit
Ethernet NIC - Packet Scheduler Miniport
(Ethernet, 100Mbps)
< Power Management >
Mains (AC) Line Status: On-Line
< Operating System(s) >
Windows System: Microsoft Windows XP Professional 5.01.2600
(Service Pack 3)
Platform Compliance: x86
< Performance Tips >
Warning 100: Large memory sizes should be made of
Registered/Buffered memory.
Tip 2546: Large memory modules should be ECC/Parity.
Tip 2: Double-click tip or press Enter while a tip
is selected for more information about the
tip.
<<< Processor Arithmetic >>>
< Benchmark Results >
Dhrystone ALU: 30.17GIPS
Whetstone iSSE3: 29.34GFLOPS
Results Interpretation: Higher index values are better.
< Performance vs. Speed >
Dhrystone ALU: 13.08MIPS/MHz
Whetstone iSSE3: 12.72MFLOPS/MHz
< Performance vs. Power >
Processor(s) Power: 129.41W
Dhrystone ALU: 233.16MIPS/W
Whetstone iSSE3: 226.72MFLOPS/W
< Performance Test Status >
Run ID: AMD Phenom(tm) 9600 Quad-Core Processor (4C,
2.31GHz, 1.81GHz MC, 4x 512kB L2, 2MB L3)
NUMA Support: No
SMP (Multi-Processor) Benchmar:Yes
Total Test Threads: 4
Multi-Core Test: Yes
SMT (Multi-Threaded) Benchmark:No
Processor Affinity: P0C0T0 P0C1T0 P0C2T0 P0C3T0
System Timer: 3.58MHz
Number of Runs: 64000 / 640
< Processor >
Speed: 2.31GHz
Type: Quad-Core
< Features >
SSE Technology: Yes
SSE2 Technology: Yes
SSE3 Technology: Yes
Supplemental SSE3 Technology: No
SSE4.1 Technology: No
SSE4.2 Technology: No
AVX - Advanced Vector eXtensio:No
FMA - Fused Multiply Add eXten:No
SSE4A Technology: Yes
SSE5 Technology: No
HTT - Hyper-Threading Technolo:No
Old 03-29-2009, 10:58 AM
Default Re: Strange Install Prob - PT mp on XP system
Addendum to above post: I noticed after posting that my Sandra report did not list my M-audio 2496 interface, which was because I didn't have same selected as the default sound device in windows. Having corrected that problem, and verifying that the M-audio device was working, I once again tried to launch PT8, with the same result as before, a hang while the program displayed a message to the effect that it was loading Structure.dpm.
I have work to do. I can't afford this.
Any suggestions as to further things to try would be appreciated.
Frankly, at this point, I'm considering this to be a serious PT8 bug.
regards,
Joel Grant Taylor
You can say whatever you like with a slide trombone but you have to be careful with words. - Louis Armstrong
Old 03-29-2009, 01:27 PM
mbeaud mbeaud is offline
You might want check this tool: http://www.digidesign.com/index.cfm?...id=37991&eid=0.
What is the Tech Support Folder?
The Tech Support Folder contains various tools for troubleshooting common issues you may
encounter with your Pro Tools system.
1. The Tech Support Utility is an easy to use program that can help you solve many
common Pro Tools technical support issues, including:
• Error messages
• Strange behavior and performance problems in Pro Tools®
• Plug-in performance problems
• Input and output problems in Pro Tools
• Launch problems
• Random application closure problems
• Unwanted demo period authorization messages
• Problems related to incompatible plug-ins and a list of installed plug-ins (and their
versions)
Before running the Tech Support Utility, please read the Tech Support Utils Read Me.
2. The Troubleshooting Sessions folder contains Pro Tools session files for the following
Pro Tools LE® systems (Windows or Mac): 003®, 003 Rack, Digi 002®, Digi 002 Rack,
Mbox® 2, Mbox 2, and Mbox 2 Pro. (Please note that you may use the Mbox Output
session to test the Monitor Outputs on the Mbox 2 Mini). These sessions can be used to
troubleshoot the following situations:
• No input or output via S/PDIF connection
• No input or output via Optical (ADAT) connection
• No input or output via MIDI ports
• No audio out of monitor outputs
Before running any of the Troubleshooting Sessions, please read the Troubleshooting
Sessions document.
Old 03-29-2009, 02:05 PM
Ok. Thanks for the suggestion. I have run all of the options in the Tech Support Utility one after the other, testing Protools launch after each one. After running option 1 to remove plug-ins warnings the program hung on Xpand! instead of on Structure and this remained the case until I restored Structure in the advanced menu, after which it went back to hanging on Structure. Any other ideas, anyone? Digi? Is there any chance that SQA can look into this? Regards, Joel
Old 03-29-2009, 02:39 PM
Does it just hang or there is an error message after some time? If so could you post it entirerly?
Old 03-29-2009, 02:53 PM
It just hangs there. If it had given me an error message I'd be thrilled. I've taken the trouble of waiting for up to 15 minutes or more a few times too, just in case there was something going on that would eventually result in an action, but no such luck.
Old 03-29-2009, 04:06 PM
BuoyRocker BuoyRocker is offline
I am having the same problem. Wish I was more cpu literrit.
I down loaded the trouble shooting/ tech thing and to be honest, I am completely lost.
I felt pretty good when PT mp8 was running smothly, which it has for three months. up until yesterday.
I will watch you post for more advise!
Old 03-29-2009, 09:40 PM
TOM@METRO's Avatar
Have you tried removing all of your plugs from their folder and placing them in a temp folder created by you? What happens then?
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2020.5 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 03-30-2009, 06:32 AM
Tom, in the initial post I discuss this strategy. What happens is that the launch hangs as soon as it gets to "loading Plug-Ins". Which is puzzling, it should just skip right over it...This makes me think the problem is occurring earlier, though that doesn't make sense to me....And to add insult to injury, if I reinstall ProTools, installing only the essential protools files, it hangs on ElasticAudio.dpm.
Does this give you any ideas?
Sometimes in this process its seemed to me that everything is broken, and that maybe I just have a really defective DVD, but I know that doesn't make much sense.
best regards,
Joel
Old 03-30-2009, 01:08 PM
TOM@METRO's Avatar
Are you running IE8?
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
Can't install Pro Tools 8! Clean install, new system, Vista! DJ Hellfire 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 31 01-09-2011 11:16 AM
Strange stuff going on, new HD2 install BoFromUnrivaled Pro Tools TDM Systems (Mac) 4 05-15-2010 01:43 AM
Strange Error after 7.3 Install blizzard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-01-2007 08:28 PM
strange playing slow prob after reinstall blueroom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 10-16-2002 12:58 AM
Urggghhh...5.1.1 install prob Bonestown 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-25-2001 11:35 AM
