Old 04-21-2020, 01:18 PM
straichen straichen is offline
Default 003 as MIDI controller in Pro Tools 10.3.8
I'm running Pro Tools 10.3.8 on a Mac Pro 5,1 OS 10.6.8.
I have used the 003 as my interface in the past, but I have upgraded recently to a system that uses the 96 I/O as my primary interface.
I would like to continue using the 003 as a MIDI controller within Pro Tools, while the 96 IO takes over as the hardware interface device.
Currently, the 96 is indeed the hardware device, and it is working. I have the 003 set to MIDI mode on the surface, and I see it as an option in the peripherals menu.
However, I havent been able to get the 003 to work as a controller. I'm not sure if I have put in the wrong settings in the peripheral menu (I'm not sure which MIDI type to select for the 003), or if there is something else I may be missing.
I also see the 003 device when I open the MIDI studio. I'm pretty sure I've got a case of user error going on. Can anyone help me figure out what I'm doing wrong? Thanks very much!
Old 04-29-2020, 11:34 PM
studio12's Avatar
studio12 studio12 is offline
Default Re: 003 as MIDI controller in Pro Tools 10.3.8
i wish to use it as well on my PT ultimate..... i`m getting info before to buy one....
Old 08-06-2020, 09:20 AM
Probably not going to work. It was never designed to do this. Start shopping for a HUI or Eucon controller
Pro Tools and a Midi Controller... earshatter Pro Tools 12 2 05-23-2017 10:12 AM
MIDI Controller for Pro Tools Marcus_Aurelius Pro Tools 10 3 02-28-2013 12:54 PM
Using Pro Tools As A MIDI Controller pavkovlr Pro Tools M-Powered (Win) 1 11-14-2011 02:24 PM
Using Pro Tools without a midi controller? Simrin MIDI 4 12-21-2008 12:22 PM
Using MIDI Controller w/ Pro Tools? strizzack 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-24-2005 11:50 PM
